valhalla360
No paticular place.
Skibane wrote: valhalla360 wrote: Plus without a platoon of healthy strong 18yr olds to do the digging, that's a lot of work.
In soft soil, it's 20 minutes for a tractor with a backhoe.
In rocky soil, add another couple hours.
Same difference...most RV'ers I know don't have a backhoe as part of their rig and you didn't address flooding in the pit.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
LouLawrence
Traveling the US!
Flooding is not an issue, you just continue a channel through your neighbors site and let the water drain out over there!
Dave H M
IL
I think we are getting the cart before the horse here.
If and after you find a property, then look at having an electrical drop put in by the local power company.
Then go from there.
The possibly exist thth you can just drive in and flip a switch.
Is what I did for my sticks and bricks home and pole barn.
valhalla360
No paticular place.
Dave H M wrote: I think we are getting the cart before the horse here.
Then go from there.
Is what I did for my sticks and bricks home and pole barn. ![wink [emoticon]](http://www.rv.net/sharedcontent/cfb/images/wink.gif)
Yes, a grid connection would be far more convenient and likely cheaper but...
In a lot of areas, they won't provide a power drop unless you are actively pursuing the building of a house or business.
Dave H M
IL
val, ![scratchead [emoticon]](http://www.rv.net/sharedcontent/cfb/images/scratchead.gif)
Note my first two sentences. Ya never know until the company is contacted.
Around here, a local drop can be put in and then there is a minimum fee per month just to keep power to the drop. As far as the cost for a drop it varies as to the distance from the main line. Mine was 200 and some change foe the hardware since I was close enough to the juice line that there was no additional charge for running line.
pianotuna
Regina, SK, Canada
30,000.00 buys a heck of a lot of solar.
Regards, Don
frankwp
Calgary, AB, Canada
Be aware that many diesel generators do not like to run for an extended time on light loads. The exhaust system will clog up in a surprisingly short time.
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
Dave H M
IL
can you clarify what you are referring to. 30K for what.
My drop was less than 300 back when and like stated, if I would not have built, there would have been a monthly charge to keep the drop alive/turned on.
I am gone and will not come back to this thread since we have long gone into the ozone layer.
valhalla360
No paticular place.
I'm sure it does...not sure how this is relevant to the conversation though.
valhalla360
No paticular place.
frankwp wrote: Be aware that many diesel generators do not like to run for an extended time on light loads. The exhaust system will clog up in a surprisingly short time.
This is another reason to be silly and buy a 30kw generator when loads are unlikely to ever get anywhere close to those levels.
