RV.Net Open Roads Forum: Solar Rv awning -- does it pencil out?
 > Solar Rv awning -- does it pencil out?
profdant139
Posted: 11/19/21 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
Great idea, but at ten thousand dollars for a thousand watts, I'm not sure it is worthwhile for me:
Article
Our trips -- pix and text
About our trailer
"A journey of a thousand miles begins with a single list."
Southern California :(
Posted: 11/19/21 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
Not in my opinion and there’s no charging when rolled up while driving or during windy days.
Dusty R
Charlotte Michigan 48813
Posted: 11/19/21 05:29pm Link  |  Quote  |  Print  |  Notify Moderator
Is there anyway of knowing how much power you can get from a solar panel in a given area ?
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 11/19/21 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
On our Winter Florida site, our awning faces North while the Sun is on the South side, so wouldn't generate anywhere near max.
While a neat idea, not overly practical in most cases.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
Skibane
San Antonio, TX
Posted: 11/19/21 11:00pm Link  |  Quote  |  Print  |  Notify Moderator
All 3 of the pictures in that article show the awning in shade - where it produces almost no power.
And in the real world, that's going to be a very common problem: Most campsites are shaded, because that's what campers want.
Shaded campsites produce little or no solar power.
And even if you're willing and able to park your RV in direct sunlight, you'll still have to deploy the awning to get any power out of it - in contrast to roof-mounted panels that produce power any time there's unshaded sunlight available.
time2roll
Posted: 11/19/21 11:49pm Link  |  Quote  |  Print  |  Notify Moderator
$10 per watt is on the high side. Pass.
675w Solar pictures back up
Skibane
San Antonio, TX
Posted: 11/20/21 01:26am Link  |  Quote  |  Print  |  Notify Moderator
You get charging-while-driving from the engine in the tow vehicle or motorhome anyway - so that's not a "problem" that this "solution" solves.
Basically, they took all the problems inherent in solar systems - and then added a few more by throwing an awning into the mix.
Do Not Want.
valhalla360
No paticular place.
Posted: 11/20/21 03:21am Link  |  Quote  |  Print  |  Notify Moderator
Sure, there are maps you can look up that estimate output when coupled with the panel ratings.
This thing though is a joke. Much better options...especially when it negates having an actual awning.
The roof is the logical first place for panels and after that smaller rigid panels that fold down to the sides would be a smarter option...and much cheaper.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
noteven
Turtle Island
Posted: 11/20/21 07:36am Link  |  Quote  |  Print  |  Notify Moderator
The Everlanders on you toob and the web doubled their panel capacity on a truck camper by using a slide system to deploy panels to the sides of the fixed set. They also shade the sides of the camper somewhat. They retract automatically if you forget when you go to move the truck.
The system uses conventional rigid panels and common rugged commercial parts.
Danieljason
United States
Posted: 11/20/21 08:22am Link  |  Quote  |  Print  |  Notify Moderator
Can I install a solar awning on my Ford E-Series Van? Is the power it generates significant? Need advice! Thanks!
