RV.Net Open Roads Forum: For those that like this style air compressor
 > For those that like this style air compressor
wanderingaimlessly
Buggs Island lake
Posted: 11/19/21 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
Horrible freight has put one on sale for Black Friday
Small comp
OK, now let the haters begin.
Bobbo
Wherever I park
Posted: 11/19/21 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
I have one exactly like that with a different label. It is actually an excellent 12v air compressor.
Bobbo and Lin
Boon Docker
Posted: 11/19/21 06:07pm Link  |  Quote  |  Print  |  Notify Moderator
X2
I have the same unit, different label. Used it many times and no complaints.
time2roll
Posted: 11/19/21 06:17pm Link  |  Quote  |  Print  |  Notify Moderator
Have had similar for 15+ years. Re-tapped the outlet to use a standard hose and chuck. As long as it has battery terminal clamps it is probably decent.
675w Solar pictures back up
ROBERTSUNRUS
Salem, Oregon
Posted: 11/19/21 09:57pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon] Hi, I bought one of those Harbor Freight compressors many years ago. If you run it without being attached to a tire valve, it will blow up. Well at least mine did. I took it back as defective for a warrantee replacement and was hassled, but they finally gave me a new one. I installed a compressor blow off valve and never had a problem since.
"> Bob ">
2005 Airstream Safari 25-B
2000 Lincoln Navigator
2014 F-150 Ecoboost
Equal-i-zer
Yamaha 2400
bucky
Raleigh metro
Posted: 11/20/21 05:03am Link  |  Quote  |  Print  |  Notify Moderator
I see you figured it out also, the screw on attachment is a royal pain. A dually makes it even worse.
2005 Cummins 3500 2WD LB quad cab dually pulling a 2014 Blue Ridge 3025RL
Lantley
Ellicott City, Maryland
Posted: 11/20/21 08:13am Link  |  Quote  |  Print  |  Notify Moderator
The above dewalt inflator is a real game changer. Its self contained no need to plug in or connect to battery. I am able to inflate my 5th wheel tires wqithout being tied to an extension cord or battery.
It is able to inflate my 110 PSI Sailun G rated tires.
Yes more expensive than the El Cheapo models but it is also more capable. I own this model and can verify it works well.
DEWALT DCC020IB 20-Volt MAX Corded/Cordless Air Inflator can run on any 1 of 3 power sources for maximum versatility: 20-Volt maximum battery, 12-Volt DC or 110-Volt AC.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Sjm9911
New Jersey
Posted: 11/20/21 08:30am Link  |  Quote  |  Print  |  Notify Moderator
I almost bought that one. But since thw new truck has a inverter and 110 outlet. I went with a small plug in 3 gal pancake compressor. Only good for 100 psi, but works well and fast.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
Esacnj
NJ
Posted: 11/20/21 09:40am Link  |  Quote  |  Print  |  Notify Moderator
Looks like Viair
Posted: 11/20/21 11:40am Link  |  Quote  |  Print  |  Notify Moderator
Esacnj wrote:
Looks like Viair
Yup. And the non sale price is actually fairly close to Viair price.
That one is slightly less cfm than the viair I bought this year for about $75. Seems comparable. Maybe even the same with a different label? Maybe a knockoff.
2017 Heartland Torque T29
