RV.Net Open Roads Forum: Do I need my WD bars just to move in the driveway?
 > Do I need my WD bars just to move in the driveway?
Page of 5
mkenyon2
Lebanon, PA
Posted: 11/19/21 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
My F150 is rated for 5,000 lbs before needing a Weight Distribution hitch, and my trailer is supposedly 4900 dry. We don't have much in there right now (not even mattresses) and it's winterized, so no water in the tank.
I should be fine just moving it around in my driveway with just the ball/hitch, right? I don't think I need the WD bars attached just to move it 10-15 feet.
MK out of PA and My Wifey
TV: 2011 Ford F150 SuperCrew 4WD (V6 3.5L/213)
Trailer: 2013 Heartland Trail Runner 25 SLE
We've only camped in 2 states? Quick, pack the trailer we have to CAMP!
bgum
South Louisiana
Posted: 11/19/21 06:50pm Link  |  Quote  |  Print  |  Notify Moderator
No
NamMedevac 70
Reno
Posted: 11/19/21 07:11pm Link  |  Quote  |  Print  |  Notify Moderator
No and No you do not need WD bars.
delwhjr
TX
Posted: 11/19/21 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
If your only moving it around to position there should be no need
2022 Rockwood 2109S
2006 Durango HEMI
time2roll
Posted: 11/19/21 10:12pm Link  |  Quote  |  Print  |  Notify Moderator
Keep it under 30 mph and you should be fine [emoticon]
675w Solar pictures back up
afidel
Cleveland
Posted: 11/19/21 11:04pm Link  |  Quote  |  Print  |  Notify Moderator
So generally it's 5000/500 where 500 pound tongue weight is the more important number for a travel trailer. You're probably over by 2-300 pounds but so long as you don't drop the trailer into a ditch you're not going to experience dynamic forces anywhere near what the engineering spec is designed for and so you'll be fine. The engineers speced that 500 pound limit for a trailer hitting a large pothole at highway speeds.
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
kellem
Shenandoah valley,VA
Posted: 11/20/21 01:46am Link  |  Quote  |  Print  |  Notify Moderator
We just recently moved a 35ft trailer with a 2001 Jeep Wrangler, entertaining.
You should be fine.
valhalla360
No paticular place.
Posted: 11/20/21 03:23am Link  |  Quote  |  Print  |  Notify Moderator
Those ratings are based on dynamic loads but the ratings are based on static loads.
Hit a pothole at 60mph and the dynamic loads are far greater than hitting the same pothole at 5mph.
Of course, it's hard to explain the dynamic loads so they give a rating based on static loads.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Timmo!
South-central Oregon...on the river
Posted: 11/20/21 08:21am Link  |  Quote  |  Print  |  Notify Moderator
And...without WD bars, it will be easier to make tight twists and turns while backing into tight spots. After awhile, you can start collecting style points --for perfectly aligning your TT with driveway's edge. Geometric perfection is a sweet sight.
JIMNLIN
Oklahoma
Posted: 11/20/21 08:40am Link  |  Quote  |  Print  |  Notify Moderator
I pulled a 10k car hauler with a 7640 lb tall blue tractor with a cab for a couple of years before Barney (mod) talked me into getting a Husky Centerline TS hitch/1200 lb bars for this combo. Boy was he right.
I can go forward or backward with the Husky WD hitch just as sharp as I did before (till the rear bumper contacts the trailer).
Your truck will be fine moving in around the rv park/campground/yard or a few miles down the road.
Page of 5
