RV.Net Open Roads Forum: Do I need my WD bars just to move in the driveway?
 > Do I need my WD bars just to move in the driveway?
Page of 5
Boomerweps
Hills of PA
Posted: 11/20/21 09:48am Link  |  Quote  |  Print  |  Notify Moderator
A LOT easier to keep a drop or lift basic ball mount for other towing and around the yard RV moving. A lot less weight to jockey around compared to the WDH head unit.
No probs at your listed weights.
2019 Wolf Pup 16 BHS Limited, axle flipped
2019 F150 4x4 SCrew SB STX 5.0 3.55 factory tow package, 7000#GVWR, 1990 CC Tow mirrors, TBC
Owens River area
Posted: 11/20/21 10:30am Link  |  Quote  |  Print  |  Notify Moderator
Nope IMO
Terryallan
Foothills NC
Posted: 11/20/21 10:50am Link  |  Quote  |  Print  |  Notify Moderator
NamMedevac 70 wrote:
No and No you do not need WD bars.
Please explain? The hitch on 150 are rated for 500lb weight carrying. His tongue weight will be over 500lbs. While no he doesn't need the WDH to move it in the drive way. It would be unsafe on the highway, not to mention it would unload the front axle and cause sway with out the WDH.
And of courser it is possible I misunderstood your post.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Posted: 11/20/21 11:13am Link  |  Quote  |  Print  |  Notify Moderator
And it’s ill informed opinions like these that keep the wdhs flying off the shelves.
To the point that a newbie like the OP is afraid to move the camper in their driveway without a wdh!
@Terryallen, if I hadn’t read so many of your misinformed posts regarding towing, I’d swear you are trolling.
2017 Heartland Torque T29
Mike134
Elgin, IL
Posted: 11/20/21 02:35pm Link  |  Quote  |  Print  |  Notify Moderator
mkenyon2 wrote:
I should be fine just moving it around in my driveway with just the ball/hitch, right?
Yep In fact you might want to get a simple 2-5/16 ball on a 2"-4" drop shank so you don't need to muscle the WHD hitch head when just moving around the driveway. I have a long driveway so I can get the rig up to about 20 mph and see just how well truck brakes alone stop it.
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
bcbouy
100 mile house
Posted: 11/21/21 07:20am Link  |  Quote  |  Print  |  Notify Moderator
i use my side by side to move my 21 foot deck boat.it weighs close to 3k lbs with the trailer i'd guess.
2012 ram 2500 hemi crew cab sb 4x4 2015 northstar 850 sc 14.5 g3 guide custom fly fishing boat
Timmo!
Far away from this WOKE website!!!!!!!!!!!!!!!!!!!
Posted: 11/21/21 07:38am Link  |  Quote  |  Print  |  Notify Moderator
Hmmm, my 2005 F150 has a 5,000 lb trailer (towing) capacity with a 500 lb tongue limit, but with WD, the numbers nearly double to 9,900 lb and 990 lbs respectively. So, yes the WD bars increase the tongue's load capacity but hard to imagine that moving a 4900 lb rated trailer in his driveway would overburden his truck.
Terryallan
Foothills NC
Posted: 11/22/21 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
Where was I wrong? A WDH is absolutly needed for a TT with a tongue weight over 500lbs on a F150. Maybe it's not me that is ill informed. And in truth. I feel the same about your posts.
Terryallan
Foothills NC
Posted: 11/22/21 02:24pm Link  |  Quote  |  Print  |  Notify Moderator
And I agree.
time2roll
Posted: 11/22/21 02:32pm Link  |  Quote  |  Print  |  Notify Moderator
The question specifically said moving the 4900# trailer less than 20' in his own driveway.
Why do you think a WDH is needed for this?
675w Solar pictures back up
Page of 5
