RV.Net Open Roads Forum: General RVing Issues: Camera/tire monitoring combo??
 > Camera/tire monitoring combo??
wowens79
Georgia
Posted: 11/20/21 05:13am Link  |  Quote  |  Print  |  Notify Moderator
Has anyone seen a combo tire monitor/rv camera system?
There are hundreds of individual systems, but it seems like a combo would be nice to only have the one screen in the cab, and would be easy to do.
2002 Chevy Silverado 1500HD 6.0l 241k miles and climbing
2016 Heritage Glen 29BH
2003 Flagstaff 228D Pop Up
way2roll
Wilmington NC
Posted: 11/20/21 08:37am Link  |  Quote  |  Print  |  Notify Moderator
I think the challenge is that these systems are completely independent of each other and manufactured by completely different companies. Perhaps there is a TPMS that will work with an app that you can cast to a head unit display.
CA Traveler
The Western States
Posted: 11/20/21 08:42am Link  |  Quote  |  Print  |  Notify Moderator
My tire monitoring system is a TST TPMS, no need to watch unless the alarm goes off, in fact it's distracting to watch as it rotates through the tires. My rear camera is occasionally used to check the toad or for lane switching.
I wouldn't want a combined unit.
GPS is another useful display device as well as engine monitoring displays.
2014 Grand Cherokee Overland
Bob
Jack_Diane_Freedom
Burlington Ontario Canada
Posted: 11/20/21 10:22am Link  |  Quote  |  Print  |  Notify Moderator
I would expect the market for such a device would be so small it would not be worth it to a manufacturer to develop and promote it.
philh
Belleville MI
Posted: 11/20/21 08:28pm Link  |  Quote  |  Print  |  Notify Moderator
Ford OEM [emoticon]
ItsyRV
Lost on the Blue Ridge Parkway
Posted: 11/20/21 08:51pm Link  |  Quote  |  Print  |  Notify Moderator
I have an Android tablet with an OTG adapter and USB hub. My backup camera control unit, dash cam, an older android phone used for storage and apps, and my aftermarket engine monitor all connect to the hub that connects to the tablet. My TPMS and refrigerator temp sensor are all Bluetooth connected to that tablet. The mapping, travel planning, and all the other needs apps are on the tablet.
Basically I created a central display and controller on the dash. It's customizable as to what I see and how. I can switch to various other displays with a touch of the screen. For the most part, I keep a split display the backup cameras and current travel map. All others are just icons along the edge. If I need to see something else, just press the icon to popup that Info and press again to bring back the main screen. I do have it so that if an attention issue occurs (like the TPMS alarm) the icon flashes red. And yes, the sounds are on so all alarm/alerts are heard.
One word of caution, make sure the tablet is large enough to create a readable experience, the you keep the in-use display other icons to a minimum so you're not clogging or squishing the needed display from excess icons or displays, the USB connected devices need to be non-usb powered as the tablet just can't support those power hog devices, and that the tablet itself can take the traveling environment.
1994 Itasca SunDancer 21RB - Chevy G-30 chassis.
