Urriellu
Full time through AZ, NV, UT, CO, ID, WY, MT
Hello, I have a Ford Ranger 2019 that does 18-21mpg on the highway at around 65mph. I have just purchased a GD 17MKE which is a 21', 6400 GVWR, travel trailer.
I expected to go from 18-21mpg not towing down to maybe 11-13mpg while towing.
Unfortunately I'm doing 8.5mpg at 65mph or 7.4mpg at 75mph.
My brake controller seems to work. RV tires are at 60psi, truck tires at 40psi.
Does this seem reasonable?
Thank you!
Jack_Diane_Freedom
Burlington Ontario Canada
That is what you will get towing. Perfectly reasonable.
Near Bishop, California
Towing at 75 may be legal but it isn’t “fuel wise” nor is it safe. Two panic stops in the last two years. Thankfully both were at 55.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist. 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
MFL
Midwest
Welcome to the forum!
Yes, sounds reasonable, for the speed. I would not tow 6K more than 65 mph with that truck. While some of the new trailer tires are marked M, or N for speeds of 81 mph or more, most RV ST tires are rated to 65 mph.
If your ST tires show 65 psi max, I'd run them at that. Not knowing your tongue weight, or what you have for truck tires, hard to say on that.
Jerry
afidel
Cleveland
Yup, welcome to the world of towing. I got 11.1 mpg at 68mph average speed with my first trailer but it was 7' wide and 9' 3" tall. My new trailer is more standard 8' wide and 11' 2" high and now I get 10-7 at 60-65 depending on how much elevation change is involved. I don't have as much experience with the new trailer (only 2 long trips and a half dozen weekend trips) but it looks like 8.5-9 is going to be my "new normal", though I have to plan on 7 for fuel range between gas stations.
2019 Dutchman Kodiak 293RLSL
2015 GMC 1500 Sierra 4x4 5.3 3.42 full bed
Equalizer 10k WDH
Terryallan
Foothills NC
Urriellu wrote: Hello, I have a Ford Ranger 2019 that does 18-21mpg on the highway at around 65mph. I have just purchased a GD 17MKE which is a 21', 6400 GVWR, travel trailer.
Thank you!
Sounds about right. However you are more than likely out running your tires. There are only about 3 ST tires that are rated for more than 65MPH. And the manufacturer probably didn't spring for the extra money. Plus 75 is awful fast to be towing 6000lb with a small truck
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
MFL wrote: Welcome to the forum!
Jerry
Most radial 14” ST tires are now rated >65mph. Even the Maypops.
2017 Heartland Torque T29
OP, welcome!
Yes that mileage seems reasonable. Especially given your stated location(s). It ain’t like towing eastbound with a tail wind through the flat-lands.
You are wringing just about every last HP out of that tiny (but impressive) motor and basically using all the rated capacities of the truck to their fullest.
The fact that it will pull that trailer at 75mph is impressive, but you can’t expect fuel economy to be any more than dismal while doing it. Not you, not the truck, that’s just how it works.
time2roll
Normal. Try 58-62 if you want a little better efficiency. 75 is too fast anyway IMO.
675w Solar pictures back up
dodge guy
Bartlett IL
Yep, sounds about right.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
