RV.Net Open Roads Forum: Towing With Water Pump Switched On. Burn Up Pump??
 > Towing With Water Pump Switched On. Burn Up Pump??
2oldman
So Cal
Posted: 11/29/21 12:07pm Link  |  Quote  |  Print  |  Notify Moderator
Njmurvin wrote:
I don't leave it on....There are lots of risks associated with camping. This is one that's just too easy to avoid.
I hear that.
I don't hook up to city water either as I cannot easily turn that off at will. And my coach being old has a few pesky leaks that city water pressure will breach (even with a reducer), but not pump and tank.
When my coach was newer, I could tow with the pump on (actually by mistake) and not have a problem. But now, when I get to the campsite, and turn on the pump, it will run but not pressure up until I flush the toilet or run the shower. I assume road vibration is causing water in those areas to leak out. To where I have no idea.
* This post was edited 11/29/21 12:14pm by 2oldman *
