RV.Net Open Roads Forum: Travel Trailers: bypassing the battery
 > bypassing the battery
gerryskid34
reading, pa.
Posted: 11/20/21 04:30pm Link  |  Quote  |  Print  |  Notify Moderator
Hello, please excuse my ignorance, but can I remove my battery and hook up the pos and neg connecting terminal wires directly to still have access to a/c power in my outlets?
I realize the battery is needed for some functions like lights and what not, but I am interested in keeping the a/c power to wall outlets to run electronic mouse/bug repellants thru the winter.
Is there any danger in doing this and what so? Can what I am asking just be accomplished by turning off the breaker for the invertor and if so, would it be listed in my fuse area? Thank you for your help.
Dave
MFL
Midwest
Posted: 11/20/21 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
Your post is a bit confusing?
Are you saying you will be connected to shore power? If so, why not leave the battery in place. It won't freeze if kept charged. Are you concerned about theft of battery?
You said inverter, but maybe meant converter? Is your converter a smart model, with float charge?
A different type of rodent deterrent may be a better option?
Jerry
Bobbo
Wherever I park
Posted: 11/20/21 06:10pm Link  |  Quote  |  Print  |  Notify Moderator
The battery has NOTHING, whatsoever, to do with the 120v wall outlets.
Removing the battery and hooking the positive and negative wires together WILL give the converter/charger a direct short and blow the fuses. Hopefully, that is all it will do. If you are lucky.
Removing the battery, and NOT hooking the positive and negative wires together, is OK, maybe. (Be sure the positive wire is isolated and not touching ANYTHING.) It depends on which converter/charger you have. Some of them require a battery in the circuit, and some do not.
Bobbo and Lin
time2roll
Posted: 11/20/21 07:21pm Link  |  Quote  |  Print  |  Notify Moderator
on edit: IN THE ABSENCE OF A RED WARNING STICKER STATING OTHERWISE
If the RV is plugged in, the battery can be removed. All systems (both 12v and 120v) will work.
And yes a few items might be connected direct to the battery in addition to the main cables. These items need to be connected to the main cables to function.
* This post was edited 11/21/21 03:19pm by time2roll *
675w Solar pictures back up
Huntindog
Phoenix AZ
Posted: 11/20/21 10:28pm Link  |  Quote  |  Print  |  Notify Moderator
NOT ALWAYS!!!
This is a blanket statement, that is not true for all RVS.
Huntindog
100% boondocking
2021 Grand Design Momentum 398M
2 bathrooms, no waiting
104 gal grey, 104 black,158 fresh
FullBodyPaint, 3,8Kaxles, DiscBrakes
17.5LRH commercial tires
1380watts solar,800 AH Battleborn batterys
2020 Silverado HighCountryC CD/A 4X4 DRW
dodge guy
Bartlett IL
Posted: 11/21/21 06:02am Link  |  Quote  |  Print  |  Notify Moderator
You would just leave the battery connections loose (protect the + terminal). Then you could do as you ask.
I wouldn’t leave the battery in with the built in charger all winter. Those converter/chargers are cheap and will over charge and boil the water out of the battery. Now you could disconnect the battery and put a battery tender on it.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
CA Traveler
The Western States
Posted: 11/21/21 07:45am Link  |  Quote  |  Print  |  Notify Moderator
If you have a good 3 stage charger and good battery then just leave everything connected?
You might be able to disconnect the battery w/o incident but it depends on your equipment. If OK then put a full battery disconnect switch on the negative battery cable. Never connect positive and negative wires together which is a direct short.
Or why not just use an extension cord for the items you want to power?
2014 Grand Cherokee Overland
Bob
bgum
South Louisiana
Posted: 11/21/21 07:59am Link  |  Quote  |  Print  |  Notify Moderator
I disconnect the negative wire from the battery and flip the breaker off for the converter in the power box. That way I have 120 voltage in the camper. I also hook a 6 watt solar charger to the battery to keep it charged.
CA Traveler
The Western States
Posted: 11/21/21 08:08am Link  |  Quote  |  Print  |  Notify Moderator
Just for information: We picked up a rat in Flagstaff AZ and tried every device known to man to catch him while he had a steady diet of apples, peanut butter, bacon etc and chair cushion for comfort. We did not want to use poison and deal with a dead rat that we couldn't find. He stole the mouse trap bait, ate his way out of the biggest glue traps? Electronic repelant devices were like music to him. Rat trap? Nope, he read the label "Danger rat trap" and totally avoided it. We finally caught him in a live trap in Denver, CO.
Near DVNP, California
Posted: 11/21/21 08:12am Link  |  Quote  |  Print  |  Notify Moderator
Why would you remove the battery? Charged it won’t freeze. I suggest lots of reading about RV electricity before you experiment.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, 300 watt solar-Lossigy 200 AMP Lithium battery. TALL flag pole. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
