RV.Net Open Roads Forum: Tech Issues: Onan microquiet 4000 cranking issue
 > Onan microquiet 4000 cranking issue
Rangoon
Michigan
Posted: 11/21/21 06:05am Link  |  Quote  |  Print  |  Notify Moderator
Anyone had this issue with there Onan generator. When you hold down the start button whether it’s inside the house or the one on the generator, it cranks for a split second and then stops and then cranks again and then stops. Most of the time it will start after priming but I can’t pinpoint why it’s doing this. I’ve replaced the solenoid, the starter, and checked all my wiring. This form won’t let me upload a video but here’s a link to my YouTube channel of me trying to start the generator. https://youtu.be/Za5ONdKySrI[image]
Bobbo
Wherever I park
Posted: 11/21/21 06:51am Link  |  Quote  |  Print  |  Notify Moderator
Rangoon's link
New members can't post links till they hit so many posts. I don't remember the number.
Bobbo and Lin
enblethen
Moses Lake, WA
Posted: 11/21/21 08:19am Link  |  Quote  |  Print  |  Notify Moderator
Sounds like there is a loose or dirty battery connection.
Bobbo, thanks for doing link!
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
pianotuna
Regina, SK, Canada
Posted: 11/21/21 09:43am Link  |  Quote  |  Print  |  Notify Moderator
Rangoon,
Welcome to the forums.
Check for voltage drop under load. What voltage are the batteries? (again under load).
Regards, Don
CA Traveler
The Western States
Posted: 11/21/21 01:44pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like a weak battery or marginal cables.
2014 Grand Cherokee Overland
Bob
2112
Posted: 11/22/21 05:08am Link  |  Quote  |  Print  |  Notify Moderator
Measure the battery voltage in 2 steps
1st while trying to start it, measure the battery voltage while touching the battery posts. Touch only the lead posts with the probes. The battery voltage dropped to what voltage?
2nd while trying to start it, measure the voltage at the cable connectors connected to the battery. Only touch the cables. If you have exposed copper cable, measure there. That will test the crimp. What did the voltage drop to?
Is there a voltage difference between the 2 measurements?
2013 KZ Durango 2857
Rangoon
Michigan
Posted: 11/22/21 08:33pm Link  |  Quote  |  Print  |  Notify Moderator
Im embarrassed to say it was just a bad ground to the chassis. It was secure so I didn’t think any thing would be wrong. I took it off to check and to had a lot of rust underneath. I cleaned it up and put dielectric greas on it and put it back together. It cranks like new. Thanks for all the help.
2112
Posted: 11/23/21 05:30am Link  |  Quote  |  Print  |  Notify Moderator
We were suspecting a bad connection somewhere. I had my money on a bad crimp.
Glad you found it
enblethen
Moses Lake, WA
Posted: 11/23/21 06:23am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the update!
