RV.Net Open Roads Forum: Tech Issues: Converting Honda generator to propane
 > Converting Honda generator to propane
Reisender
NA
Posted: 11/23/21 08:37am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
cons propane is more expensive than gasoline.
generator is some what thirsty for propane
output wattage is some what lowered.
pros
no worries about varnish build up in carburetor
oil changes less frequently
spark plugs last a lot longer.
I'd get a trifuel one--so that natural gas could be used.
Just have fun!
Did not know about the less frequent oil change and spark plug. How less frequent for oil change. We use ours exclusively on propane. Never had gas in the tank.
Skibane
San Antonio, TX
Posted: 11/23/21 10:23am Link  |  Quote  |  Print  |  Notify Moderator
^An oil sample analysis from Blackstone Labs or similar will tell you if you need to change it more often.
Then again, the analysis is 20 bucks - and a pint of full synthetic oil is only 2 bucks...
ajriding
st clair
Posted: 11/23/21 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
The ONE guy that actually answered your question with a pro/con list is correct, and another added that propane does have a cleaner burn and cleaner exhaust.
He also forgot that propane can store a very very long time, but gas has a shelf life.
That's about it for pros unless you are parked on your land with a big underground propane tank or would be using natural gas from the grid. The varnish build up from gas is a minimal one as that can be negated. Worried about replacing spark plugs? Stop, you can't afford propane to begin with.
The big con is the availability of getting propane quick and easy. Gas is easy and everywhere and unless I drive into the big rig section at the back of the travel center gas station there is always a gas hose just inches away. Doing a BBQ tank swap at the gas station or store is not a quick transaction either. The things people come up with just to make a comment...
An e way....
Reisender
NA
Posted: 11/23/21 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
I guess for some of us the other pro is transporting and storing gas vice propane. Propane is just easier for us. To each his own.
MEXICOWANDERER
las peƱas, michoacan, mexico
Posted: 11/23/21 06:53pm Link  |  Quote  |  Print  |  Notify Moderator
I converted and serviced dozens of LPG gensets. The larger ones were Wisconsin V4 37.5 horsepower air cooled.
Intermittent selective loading is the big advantage of LPG fueled generators
Start engine use microwave, shut down.
Start engine charge flooded batteries for 3 hours then shut down.
Nkcase pse
Keep in mind changing over an air cooled generator makes it operate at a significantly higher temperature. This is where I met Pabst ventilation fans.
The engines also gain crankcase pressure meaning oil leaks are increased.
When I ran a one ton pickup exclusively on LPG I built a special engine with 12.t to 1 compression, large valves and special camshaft. The rest was about as much power as stock engine and recovered about half the lost economy. That was several decades ago when scarce Mexican premium gasoline wasn't equal to cheapie USA regular gasoline and butane was ? the price of regular gas.
When switching away from gasoline the benefits should be weighed against the minuses. That pickup had a stake bed on it with a vertically stacked pair of 83 gallon motor fuel tanks.
valhalla360
No paticular place.
Posted: 11/24/21 01:28am Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
Diesel and gasoline are not always avaible at the same "delivery point". Stop for gasoline, move RV to get propane, move again to get diesel.
And yes, I've been at stations that have gasoline and propane but no diesel.
I've never been to a gas station that has diesel and not gasoline...easy enough to walk a 5 gal jug to the gas pump if they aren't at the same location (which they usually are unless you go to a truck stop).
Lots of gas stations don't have propane and vast majority do not have the ability to fill a tank (only swap, so you are limited to 20# BBQ tanks).
Yes, some gas stations don't have diesel...if you have a diesel truck, you probably aren't stopping there in the first place unless it's purely to get fuel for the generator.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Dusty R
Charlotte Michigan 48813
Posted: 11/24/21 07:36am Link  |  Quote  |  Print  |  Notify Moderator
Some places that swap 20# LP tanks, don't fill them to 20#.
pianotuna
Regina, SK, Canada
And if, like me, you have a fixed tank propane becomes just that much harder.
Regards, Don
Skibane
San Antonio, TX
Posted: 11/24/21 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
I generally use ethanol-free gasoline in my small engines - which entails finding a gas station that sells it.
Nowadays, propane exchanges are just about everywhere. Even Walgreens and 7-11 have them.
Basically, just about any place you can buy a bag of ice, you can also exchange a tank of propane.
Bobbo
Wherever I park
Posted: 11/24/21 06:37pm Link  |  Quote  |  Print  |  Notify Moderator
Agreed. All of the places that I know of sell you 15# of propane. Read the label on the propane bottle. It will say.
Bobbo and Lin
