RV.Net Open Roads Forum: Technology Corner: TV antenna
 > TV antenna
ice2fire
Summer = Ontario. Winter = Arizona
Posted: 11/21/21 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
After many years in a RV park, we are going roaming. We would like to see some TV on the way Eg news. What kind of antenna do we need? Ours is 12 years old and never been used. Thanks
2010 30' Heartland North Country, on a site in Tucson, Arizona.
Anza-Borrego Desert SP area
Posted: 11/21/21 03:26pm Link  |  Quote  |  Print  |  Notify Moderator
My factory installed cheapo knock off antenna works fairly well. Try your’s before you replace. Don’t discount on-line streaming of local TV news.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Tom_M
New Hope, MN
Posted: 11/21/21 04:39pm Link  |  Quote  |  Print  |  Notify Moderator
You do not need a special antenna. The crank-up Winegard Sensar IV (aka Batwing) is considered one of the best TV antennas for an RV. If you have a crank-up antenna it is most likely a Winegard and it should work. If it is an older Sensar III there is a snap-on attachment available that makes it the same as a Sensar IV.
* This post was edited 11/22/21 05:14am by Tom_M *
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 1978 VW Bug convertible
Minneapolis, MN
bgum
South Louisiana
Posted: 11/21/21 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
Use what came with your RV.
KD4UPL
Swoope, VA
Posted: 11/21/21 07:14pm Link  |  Quote  |  Print  |  Notify Moderator
If you already have a TV antenna then you don't need another one. It works the same as any other antenna. Some people will try to tell you that the switch to digital TV means you need a "digital" antenna. Don't take advice from such people.
bob213
Fresno, CA
Posted: 11/21/21 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
Get the add on attachment that Tom M referred to. You will have the best antenna you can get IMO.
Posted: 11/22/21 05:13am Link  |  Quote  |  Print  |  Notify Moderator
There are many out there who sell antennas they CLAIM are better than the Winegard Batwing.. they lie.. (Well most of 'em but... read on). I've seen some for sale for 100 dollars that.. Well they were 20 dollar table top UHF bowtie antennas from a local hardware or TV store.
Now there are some monster antennas NOT designed for sustained high wind (Designed to go on a tower at home) that are better but they are not practical for RV,
If You have a Winegard Batwing (Sensar II or III) consider getting the Wingman (UHF Director array) and adding it, about 30 bucks. if you have a Sensar IV (Wingman already part of it) you have the best there is.
If you have a 'Jack' antenna.. it is good but not as good as the Winegard.
IF you wish to make additional improvement the Sensar Pro from Winegard works with both the Jack and the Winegard antennas and adds additional amplification to the incoming signal. It replaces the wall plate with the switch LED 12 volt outlet and Antenna connection easy DIY install.
Example of Sensar II or III no wingman
Example of Sensar IV also looks like an II or III WITH the wingman
Winegard Sensar Pro, also comes in black
 > TV antenna
