RV.Net Open Roads Forum: Fifth-Wheels: Suggestions for a shorter 5’ver…
 > Suggestions for a shorter 5’ver…
Thermoguy
Graham, WA
Posted: 11/22/21 01:00pm Link  |  Quote  |  Print  |  Notify Moderator
bukhrn wrote:
John & Christine wrote:
Looking at 5th wheels. We are a family of 4 that doesn’t need a ton of space. Mom, dad and 2 teen boys. We are all well experienced campers. We’ve owned a few 5th wheels in the past. I’ve been looking around for a 5th wheel that fits our needs but just want to see if anyone has any suggestions. Here’s our criteria below in no particular order. Thanks
Around 30’ or less… we’re limited to this size because of the amount room in our driveway. We have a lot of vehicles.
Bunks… we just like a bunk model for the kids.
Higher end brand…. Don’t mind paying a few $$ for something of better quality.
Four season if possible…
Weight not a factor. We’re going to buy our TV after the RV.
Saw this in a CG in Northern NY, Obviously older, and not sure of the exact length, but it is the smallest 5'er I've ever seen.[image]
Now that looks like a 1/2 ton towable 5th wheel - good find.
2012Coleman
Posted: 11/22/21 01:09pm Link  |  Quote  |  Print  |  Notify Moderator
You didn't ask for 1/2 ton tow-able, but that's where you will find what you are looking for. Here are some great examples: Brochure hitch weights are for entertainment purposes only...
Reflection 150 Series 268BH - single wide rear bunks
UVW: 7,893 lbs | GVWR: 9,995 lbs | Hitch Weight: 1,268 lbs | Length: 31'11"
Reflection 150 Series 278BH - double wide rear bunks
UVW: 8,345 lbs | GVWR: 10,195 lbs | Hitch Weight: 1,321 lbs | Length: 32'11"
Reflection 150 Series 280RS - rear tri-fold soafa, but 30" 11" long
UVW: 8,566 lbs | GVWR: 10,995 lbs | Hitch Weight: 1,384 lbs | Length: 30'11"
https://www.granddesignrv.com/showroom/2021/fifth-wheel/reflection-150-series/floorplans
Experience without good judgment is worthless; good judgment without experience is still good judgment!
2018 RAM 3500 Big Horn CTD
2018 Grand Design Reflection 303RLS
philh
Belleville MI
Posted: 11/22/21 02:00pm Link  |  Quote  |  Print  |  Notify Moderator
Artic fox 27-5L
time2roll
Posted: 11/22/21 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
Mine is 26' but sadly no longer available new.
675w Solar pictures back up
John & Christine
Milford
Posted: 11/22/21 03:33pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the responses everyone.. appreciate it. Keep em coming if you don’t mind.
John & Christine
Milford
Posted: 11/22/21 03:34pm Link  |  Quote  |  Print  |  Notify Moderator
Grand Design has some great models and where I’m leaning at this point. Thanks
work2much
On the Road
Posted: 11/22/21 05:32pm Link  |  Quote  |  Print  |  Notify Moderator
If you are ok on a big budget you could talk to New Horizons. They can create a custom floor plan for you. 30’ with a bunk though would be tough to design in a 5th wheel and still have a useful kitchen and living room.
You might consider a TT.
2022 Ram 3500 Laramie CTD DRW Crew 4x4 Aisin 4:10 Air ride.
2020 Grand Design Solitude 2930RL 2520 watts solar. 600ah lithium. Magnum 4000 watt inverter.
Addy15
Minnesota
Posted: 11/22/21 05:58pm Link  |  Quote  |  Print  |  Notify Moderator
We have a Winnebago Minnie Plus 27RLTS. Right at 30 ft. No bunks, but the dinette and sofa are both a full 8 feet long and easily accommodate taller sleepers. It has a good amount of storage. Probably not 4-season. These trailers are not available new anymore, but might be a good option if you can find one.
Lantley
Ellicott City, Maryland
Posted: 11/22/21 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
My only adivice is that if you are going the bunk house route. Get a floorplan that has a seperate bunk room vs. just bunk beds.
A bunk room gives the kids a seperate place to call their own.
It also gives them a dedicated palce to store their stuff.
Giving the kids a dedicated space indirectly gives the adults.
their own space.
Camping is a great family activity which is good. Having a space to call your own when desired makes the whole experience even better.
Bunk house vs. Toy hauler.
A toyhauler can make a great versatile bunk house. The versatility of the toyhauler can also be its Achlilles heal.
A traditional bunk house has fixed storage and fixed beds. A place for everything and everything in its place.
A toy hauler lacks fixed furniture everything is in flux which allows for lots of versatility. That versatility requires more set up and take down vs. a traditional bunk house.
After camping with kids for quite a few years I have come to despise all the set up and break down required. I now limit my set up of anything unless I'm really going to use it or need it.
My days of setting up pink flamingos,antique car lights and other doo dads are over. Now I'm just a boring guy with a camping chair and maybe a table.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Njmurvin
Simi Valley
Posted: 11/23/21 01:10pm Link  |  Quote  |  Print  |  Notify Moderator
philh wrote:
Artic fox 27-5L
x2 but no bunks and they are HEAVY for their size.
2020 Chevy Silverado 3500HD Duramax 4x4 Crew Cab Standard box
2011 Arctic Fox 27.5L
