propchef
NORCAL
Just keep in mind that water does not compress and injecting too much water into the intake will cause a change in the compression ratio of the cylinder. Water will also lower the combustion temperature.
Me Again
Sunbird(Wa)/snowbird(Az)
larry cad wrote:
Sometime later!
Description
English: A KC-135A taking off with water injection to its J-57 engines
Date 30 September 2013, 15:35:08
Source USAF photo
Author USAF Photographer
This picture is from the top of our 625' tower looking over at U-Tapao. Between the B-52s and KC-135, and a war, we thought at times our buildings would fall down.
2021 F150 2.7 Ecoboost - Summer Home 2017 Bighorn 3575el. Can Am Spyder RT-L Chrome, Kawasaki KRX1000. Retired and enjoying it! RIP DW 07-05-2021
larry cad
ohio
Me Again wrote: larry cad wrote:
Sometime later!
Description
Source USAF photo
![[image]](https://i.imgur.com/b2b9N44l.jpg)
I was "next door", a few years later (from the date on your photo.)
Fun times, huh?
Our Travel Blog
Me Again
Fun times, huh?
When I arrived around the 2nd or 3rd of July 1966 there were:
200 AF Redhorse Construction guys building the runway
50 US Army
4 Marines
12 USCG Electric Techs, a W4 XO and LT CO as a construction detachment.
I rotated out on June 2nd 1967 and there were:
7,000 USAF
5,000 US Army
28 USCG
and the same 4 Marines and are probably still there!!!! They had huts down on the beach in Sattahip, with Thai ladies to clean, cook and provide for their needs.
larry cad
ohio
Fun times, huh?
50 US Army
4 Marines
7,000 USAF
5,000 US Army
28 USCG
Never made it that far west. I did get to Pleiku over on the western boarder.
Groover
Pulaski, TN
Water in the oil is always a problem if you don't make enough heat to drive the water out. Even if you don't add water the combustion process creates it. Adding water does not create a problem, just makes it more pronounced.
Every successful application that I have heard of was on engines that are already very hot from being worked to the max. Mostly racing and WWII fighters. On the fighters it was only used when gasoline alone wasn't providing enough power and then only for short periods.
Blazing Zippers
North Idaho
I used to drive a tricked out '67 Ford 4X4 with a built 390 engine. At 6000 feet elevation, there wasn't much piston knock, but near sea level in the heat---Zowwiee! The water injection quieted the knock almost completely. The system was a pain to maintain and regulate. I took it off one day and threw it far away.
polarbare21
Somewhere between Mexico and Canada
I thought I’d add this little bit of family history-
My grandfather was a WW1 aircraft mechanic, he told me that he made up a water vapor injection system so water vapor could be drawn into the air intake of the engine.
I don’t remember if he even detailed what he used or how he kept the intake from getting a gulp of water.
But I do remember he said that the water vapor helped with fuel economy, engine performance, engines ran cooler, and were cleaner because of a more complete combustion.
He said think about it, doesn’t your car run better in fog or a heavy rain?
Years later during some “lean times” I took a mason jar, and punched 2 holes in the lid.
In one hole I put a piece of copper pipe long enough to almost reach the bottom of the jar, the other end was open to atmosphere.
I put a valve in the other hole and ran a line from the valve to a vacuum line from the carburetor of my Ford van.
With water in the mason jar the carburetor drew air from atmosphere through the water
making bubbles (the amount was controlled by the valve) then drawn into the carburetor and mixed with more oxygen and fuel vapors.
Now from what I remember my little science project did result in a bit more fuel economy, but most notable was the van ran better, better throttle response.
I was pretty pleased with what looked like a miniature moonshine still, and in the winter I would add an ounce or two of gas line anti freeze.
