theoldwizard1
SE MI
The issue is charging more than discharging. Also, whether you were in use before the temperature dropped below freezing.
If you are continuously discharging, you CAN go from above freezing to slightly below freezing (23F sounds reasonable), but do not try to recharge at the temperature.
pianotuna
Regina, SK, Canada
2oldman wrote: 23.. 32? Looks like dyslexia.
Very Clever!
Regards, Don
time2roll
theoldwizard1 wrote: The issue is charging more than discharging. Also, whether you were in use before the temperature dropped below freezing.
If you are continuously discharging, you CAN go from above freezing to slightly below freezing (23F sounds reasonable), but do not try to recharge at the temperature. A good BMS will block the charging at low temperature and block discharge at an even lower temperature.
675w Solar pictures back up
jaycocreek
Idaho
Lifepo4-380ah/Lithium NMC-140ah/Solar-400 watts/Wagan & Giandel PSW/Engel & Iceco 3-1 compressor fridge freezer/5K Window AC/Honda 2K
noteven
Turtle Island
pianotuna wrote: noteven wrote: Some battery makers are now building self heating LiFeO4 batteries.
No they don’t use their own amp hours to heat. The batteries can deliver energy down to -20C battery temp.
They use energy from the charging source to warm the cells. Then they begin to charge.
Lithium batteries can accept charge at very high rates.
This is why a small generator or engine alternator charging is probably step one in a lithium system then do the solar spend to round out the system, especially if you camp in winter, forest, shade, or rainy lands.
I wonder how long the heater would take to warm the battery bank at -37 c?
Best possible charge rate for best cycle life is 0.2 c. A 0.5c works well, too. Yes, you can charge faster--but with a trade off in cycle life.
Battleborn batteries have a heated version--and it DOES draw from the battery to keep warm unless there is external power available.
If I were using them in a unit capable of -37C I would have them installed inside the heated envelope. If I had to let the unit freeze to ambient in storage at 25lbs each I would pick up the batteries and put them somewhere warm, partially charged, not needing any fussing with in storage, until I needed them again.
If you are where it gets cold, don’t buy self heaters that use their own energy would be a n option.
A guy could also use SiO2 batteries if actual cold exposure is common in the “mission”.
noteven
Turtle Island
Ray at Love Your RV channel did a cold lithium charging test using a freezer and actual measurements.
Spoiler The battery does not blow up and fail at 31.9F
jaycocreek
Idaho
noteven wrote: Ray at Love Your RV channel did a cold lithium charging test using a freezer and actual measurements.
I have also read that charging at a lower voltage is okay when it's that cold..Good test for Will instead of all the guessing floating around the net..The last video I saw of Wills,he was talking about charging a lfp with frozen cells which...At what temp does a Lifepo4 cell freeze?
dedmiston
Coast to Coast
Lwiddis wrote: I've seen some manufacturers say it is ok down to 24 but no experts. They say 32.
Pretty ironic from the guy who says so often to ignore the experts and do whatever the manufacturer says.
(DISCLAIMER: I don't know anything about these batteries, but I'm a self-proclaimed expert in irony. And yes, I appreciate the irony of a moderator calling Lwiddis out.)
Toys:
- 18 Can Am Maverick x3
- 05 Yamaha WR450
- 07 Honda CRF250X
- 05 Honda CRF230
- 06 Honda CRF230
pianotuna wrote: It depends in the individual maker.
I will second that. Slight differences in both the make up of the battery and the paranoia of the maker (IN this case paranoia means their desire to be cautious) A more cautious maker will name a higher cut off temp.
StirCrazy
Kamloops, BC, Canada
23F is -5C, which is the lowest cold weather charging temp listed by the Prismatic cell manufactures, so thats not the brands limit thats the actual cell manufctures limit. most rebranders/assemblers would put that to 32F to give them self a bit more protection from warenty claims.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
