RV.Net Open Roads Forum: Lifepo4 cold temp cut off 23F or 32F?
 > Lifepo4 cold temp cut off 23F or 32F?
StirCrazy
Kamloops, BC, Canada
Posted: 11/22/21 05:36pm Link  |  Quote  |  Print  |  Notify Moderator
Lwiddis wrote:
I've seen some manufacturers say it is ok down to 24 but no experts. They say 32.
and who are these experts and what makes them that? youtube?
personaly I think 32 was chosen because of lack of knowledge and a carry over from other Li chemistry. also since the LFP only gave them a extra 5 degrees C , and who realy camps when its 0 (sarcasm, but its how assembliers/branders would probably think) why change it. and if they leave it at 0 degrees C that gives them a 5 degree buffer for warenty claims.. win win win..
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
3 tons
NV.
Posted: 11/22/21 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
Oops, please disregard…
jaycocreek
Idaho
Posted: 11/22/21 05:55pm Link  |  Quote  |  Print  |  Notify Moderator
StirCrazy wrote:
23F is -5C, which is the lowest cold weather charging temp listed by the Prismatic cell manufactures, so thats not the brands limit thats the actual cell manufctures limit. most rebranders/assemblers would put that to 32F to give them self a bit more protection from warenty claims.
Steve
That really makes sense to me,kinda like the truck manufacturer axle ratings vs the actual axle manufacturer ratings,both different numbers..
Thanks
Lance 9.6
400 watts solar mounted/200 watts portable
500ah Lifep04
time2roll
Posted: 11/22/21 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
Two of the largest manufacturers, EVE and CATL, give 0c as the minimum to charge.
Ignore factory specifications at your own risk.
675w Solar pictures back up
Itinerant1
Itinerant
Posted: 11/22/21 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
Manufacturers seem to have their own recommendations. My GBS cells recommend -20C (-4f) to 65C (149f) for discharging, 0C (32f) to 65C (149f) for charging. Which the BMS protects for these temps.
12v 500ah, 20 cells_ 4s5p (GBS LFMP battery system). 8 CTI 160 watt panels (1,280 watts)2s4p,Panels mounted flat. Magnum PT100 SCC, Magnum 3012 hybrid inverter, ME-ARC 50. Installed 4/2016 been on 24/7/365, daily 35-45% DOD 2,100+ partial cycles.
S Davis
Western WA
Posted: 11/22/21 09:34pm Link  |  Quote  |  Print  |  Notify Moderator
I am heating my two 12v 280ah batteries, will be using a separate small agm charged by the trucks alt. I don’t plan on letting them get below 40 under normal conditions but will probably test after they cold soak once for a idea just Incase.
Twin 280ah LifeP04
Tom_M
New Hope, MN
Posted: 11/23/21 06:12am Link  |  Quote  |  Print  |  Notify Moderator
jaycocreek wrote:
From ExpertPower web site:
Discharge: -4 — 140°F
Charge: 32 — 140°F
https://www.expertpower.us/products/ep12100-100ah
The Amazon listing is a typo.
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 2016 Mini Cooper convertible on tow dolly
Minneapolis, MN
jaycocreek
Idaho
Posted: 11/23/21 07:19am Link  |  Quote  |  Print  |  Notify Moderator
You would think they would fix there typo..lol
My cheapo 100ah lifepo4 battery is pretty generic temp wise as I assume most of them are...The 23F cutoff just caught my eye...
otrfun
On The Road
Posted: 11/23/21 11:24am Link  |  Quote  |  Print  |  Notify Moderator
I believe there's general agreement the majority of lifepo4 manufacturers specify >32f as the minimum temperature you can "safely charge" a lifepo4 at it's maximum rated charge current. Safely charge defined as charging that results in no reduction in a lifepo4's long-term performance---the ability to deliver 3000-4000 charge cycles while maintaining at least 80% of the original ah rating of the battery.
As StirCrazy alluded to earlier, if a particular manufacturer specs their lifepo4 as capable of maximum charge current at <32f, my guess, it's just a marketing strategy. Their bean-counters have probably determined any increased costs for warranty claims (to support the lower charge cut-off temp) is more than offset by the increased sales to folks who actually believe they have a better lifepo4. Again, more than likely marketing strategy vs. a battery/cell with any real added capability.
Lastly, some see the lifepo4 32f low-temp charge cut-off as all or nothing in terms of charging--ok to charge at 33f---not ok to charge at 32f. That's not necessarily the case. It is possible to safely charge at <=32f . . . if you're willing/able to reduce the charge current (and have a BMS which permits charging at <=32f). I find it very interesting that Trojan actually specs the maximum allowable charge current for their 110a Trillium lifepo4 down to -4f (-20c).
BFL13
Victoria, BC
Posted: 11/23/21 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
Previously, Trillium info was to limit charging amps on a sliding scale from just under freezing to well above freezing, but their data sheet now shows full 110amp charging right from freezing on up, and reduced charging amps below freezing to a lower temp than before.
No idea if anything new with the LFPs that take heat from a charger before allowing charging, but it was 5C/40F before they allowed charging to start.
I kept asking on here about what to charge at between freezing and 5C and how you could throttle the amps of your charger to do that, but got nowhere. Seems Trillium has changed their story lately. if true for all LFPs now, it is moot.
Perhaps there has been more experience /data with LFPs or they have changed the formula a bit for making the cells, not a clue.
Lesson is to keep up with the latest on all this, because what you learned last year might now be wrong. Eg I see Trillium has "retired" the Trillium Owners Guide, but do have the new charging guide in the Data Sheet
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
