RV.Net Open Roads Forum: Tow Vehicles: Ford Gas 6.2 vs 7.3
Search only in Tow Vehicles
 > Ford Gas 6.2 vs 7.3
riltri
Husk & Steinhatchee
Posted: 11/22/21 03:41pm Link  |  Quote  |  Print  |  Notify Moderator
We no longer travel with our 13k lb 5th except back and forth to Florida from the NC mountains. I'm trading my GM diesel longbed for a gas standard bed. Probably going with a Ford F250 (although I am still considering a RAM). Not ideal for extended traveling but to make 2 pulls (4 days) per year, I'm opting for something that makes sense for day-to-day use.
Everything I've read/heard is that the 6.2 is a workhorse which should give me 250K+. I'm a bit concerned about the 7.3. Have read a couple of bad reviews and it has not been around long enough to be certain about the reliability of the motor.
Will appreciate any suggestion/comments.
Blue Ridge Mtns - NC
wanderingaimlessly
Buggs Island lake
Posted: 11/22/21 05:04pm Link  |  Quote  |  Print  |  Notify Moderator
If you like the Ram, why not a 6.4 with the 8 speed?
ram 2500
FishOnOne
The Great State of Texas
Posted: 11/22/21 05:10pm Link  |  Quote  |  Print  |  Notify Moderator
Yes the 6.2 has an excellent reputation for reliability. Known problem has been broken valve springs but that's about it. Some of the early 7.3's had front main seals fail and caused oil leaks and torque convertor problems, but I believe these issues have been resolved.
For a truck that doesn't tow 99% of the time the 6.2 would be the better choice just for the slightly better fuel economy.
'12 Ford Super Duty FX4 ELD CC 6.7 PSD 400HP 800ft/lbs
"250k Miles"
'16 Sprinter 319MKS "Wide Body"
riltri
Husk & Steinhatchee
Posted: 11/22/21 05:19pm Link  |  Quote  |  Print  |  Notify Moderator
ram 2500
Two issues I have had in this area. 1) No RAM dealer will even seriously discuss ordering one to my specs. 2) Ridiculously low trade offer from RAM dealers. The local Ford dealers are very helpful/accomidating.
Nothing against the truck but I have no desire to deal with the 3 dealers near me.
wanderingaimlessly
Buggs Island lake
Posted: 11/22/21 05:37pm Link  |  Quote  |  Print  |  Notify Moderator
Large Ram dealer in NC, good reputation.
31 Dodge
MFL
Midwest
Posted: 11/22/21 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
If you get the 6.2 to tow your 13K FW, Id suggest the 4.30 gears.
You said you don't want the Ram, and the Ford, or GM, will allow more clearance from axle center, to rear of cab.
Jerry
riltri
Husk & Steinhatchee
Posted: 11/22/21 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
Jerry
Thanks....I had not thought about the difference in cab clearance!!
wowens79
Georgia
Posted: 11/23/21 02:51am Link  |  Quote  |  Print  |  Notify Moderator
I’d go with the 7.3. After the first year they seem to have worked the kinks out, and from reports I’ve read, the fuel mileage actually seems better with the 7.3.
7.3 is a simpler pushrod design, and it’s torque curve is much better. It hits 400lbs or torque at 1500 rpms.
2022 Ford F-350 7.3l
2002 Chevy Silverado 1500HD 6.0l 268k miles (retired)
2016 Heritage Glen 29BH
2003 Flagstaff 228D Pop Up
spud1957
NB
Posted: 11/23/21 05:19am Link  |  Quote  |  Print  |  Notify Moderator
Think you're pushing the limits of the 6.2.
Another consideration is 6 vs 10 speed transmission. If you go with a F250 with the 6.2, you get the 6 speed. F250 with the 7.3, you get the 10 speed.
If you get a F350, you get the 10 speed with both engines.
manley
Wichita Falls, TX
Posted: 11/23/21 05:25am Link  |  Quote  |  Print  |  Notify Moderator
I have the 7.3 with the 3.55 rears. I like it, but it’s thirsty.
2021 F250 XLT FX4 SCREW Godzilla 7.3L
Hensley Arrow
2017 Open Range Light 272RLS
