ReneeG
Meridian, Idaho
With the TV in our signature, we never tow using cruise control, preferring to manually be in control when driving (if that makes sense), but always have Tow Mode on. Going down hills when tapping the brake, the trailer brakes are automatically engaged as well. We only use the manual trailer brake control for extra assurance or a little help as needed, which is rarely. Remember in the Mountain West Directory, in the introduction, the author states, "You can go down a mountain a thousand times too slowly, but only once too fast."
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
Fulltimer50
Eloy, AZ
18 wheelers dont seem to have a problem.
George
2011 F350 PSD CC LB 4X4 DRW Lariate
2015 Mobile Suites 41RSSB4 5th Wheel
cummins2014
Utah
ReneeG wrote: With the TV in our signature, we never tow using cruise control, preferring to manually be in control when driving (if that makes sense), but always have Tow Mode on. Going down hills when tapping the brake, the trailer brakes are automatically engaged as well. We only use the manual trailer brake control for extra assurance or a little help as needed, which is rarely. Remember in the Mountain West Directory, in the introduction, the author states, "You can go down a mountain a thousand times too slowly, but only once too fast."
I've found with my 2014 Ram cruise on ,and usually set 5 mph lower then I want to descend a mountain grade, It will gain that 5 mph then maintain the desired speed . I have yet to go down a grade here in the mountain west that it didn't maintain the set MPH that I wanted without any further input from me.
The problem for me with just letting off the pedal ,and letting it slow going down a grade is that it slows too much, then back on the pedal , repeating this several times . Now hearing this explanation for auto I may give that a try , like one said he had the feature ,but didn't know how it worked . This was from a ford owner ,so a Ram truck may be different .
Cummins12V98
on the road
Auto mode is useless unless you are towing a lighter RV and smaller grades at least with RAM trucks.
I also set my cruise control at a lower speed to maintain the actual speed I want. It varies depending on how steep the grade is. I also on steep grades select the gear that puts me up near the redline for best braking.
I am glad I don't have the ability for the truck to apply my trailer brakes. I like controlling me descent with cruise and proper gear selection for the grade. I never use Auto mode, I have tried but found it useless for my large load.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Retired JSO
North Georgia Mountains
I tow in tow mode and use cruise control all the time with the exhaust brake engaged. The OP has a 2019 F-350, I have a 2018 F-350, my exhaust brake has no auto, it’s either on or off.
ReneeG
Meridian, Idaho
Retired JSO wrote: I tow in tow mode and use cruise control all the time with the exhaust brake engaged. The OP has a 2019 F-350, I have a 2018 F-350, my exhaust brake has no auto, it’s either on or off.
We have a 2011 F350 and the true engine compression brake (not exhaust) is only off or on with setting the Tow Haul Mode.
Cummins12V98
on the road
"We have a 2011 F350 and the true engine compression brake"
Please explain.
JKJavelin
Milwaukee, WI
Cummins12v98, I believe this how the Ram engine brake works:
Full mode, just letting off the accelerator will activate the engine brake.
Auto mode, you must tap the brake pedal to activate the engine brake.
I prefer the Auto mode to prevent it slowing down all the time, so I am able to coast. My trailer weighs near 12k lbs.
JK
2018 Ram 3500 Laramie Cummins 6.7
2016 Open Range RF316RLS
Titan Disc Brakes
Trailair pinbox
Morryde SRE-4000 w/ wetbolt kit
Demco Autoslide
570 watts of Solar
2017- 21 Nights
2018- 75 Nights
2019- 138 Nights
2020- 72 Nights
2021- 122 Nights
2022- 68 Nights
time2roll
If the trailer is pushing the truck sideways in a curve hard enough to jack-knife using the Jake.... you are going too fast for the conditions.
675w Solar pictures back up
KD4UPL
Swoope, VA
When I drove 18 wheelers with jake brakes I never applied the trailer brakes going down hill. It never even occurred to me. You're thinking too hard about this.
