RV.Net Open Roads Forum: Tow Vehicles: Ambient Temp Sensor Troubleshooting
Search only in Tow Vehicles
 > Ambient Temp Sensor Troubleshooting
TurnThePage
North ID
Posted: 11/23/21 03:22pm Link  |  Quote  |  Print  |  Notify Moderator
Right up front, this is not an RV related question, but I know there's tremendous vehicle knowledge and experience to be had here.
We have a 2012 Ford Fusion that doesn't know the outside temperature and thus is unable to heat/cool the inside properly. The temp display will sometimes be accurate briefly, but will soon start drifting downward, eventually bottoming out way below zero, before wandering back upward some. It goes all over the place. Internet research indicated that I should replace the ambient temp sensor, which I did, twice. The sensor I replaced is behind the front bumper and fascia. Is there another sensor? Could a bad fuse cause that behavior? I'm getting ready to remove it all together to see if there's any difference.
2015 Ram 1500
2004 Pioneer 18T6
enblethen
Moses Lake, WA
Posted: 11/23/21 03:53pm Link  |  Quote  |  Print  |  Notify Moderator
There should be two. You replaced the one for the engine control and not the heating/cooling system.
My Chrysler has the passenger comparment sensor internal to the temperature control unit.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
ae5573t
Alabama
Posted: 11/23/21 03:57pm Link  |  Quote  |  Print  |  Notify Moderator
I had a similar problem and like you I replaced the ambient temperature sensor. It didn't fix the problem. I had to replace the ambient temperature sensor connector. That is what fixed my problem.
2018 Thor Tuscany 42GX
2015 Jeep Wrangler JK Unlimited
dodge guy
Bartlett IL
Posted: 11/23/21 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
Some cars have 2 sensors, one behind the grille and the other in an outside door mounted mirror.
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
TurnThePage
North ID
Posted: 11/23/21 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks folks. I'll do some more research.
jfritz_drfritz
canada
Posted: 11/25/21 08:40am Link  |  Quote  |  Print  |  Notify Moderator
If I understand this correctly you have two problems. The first is that the outside temperature does not display correctly. I would agree that this is likely related to the ambient temperature sensor in front. However, there is almost certainly a separate sensor that measures the interior car temperature. Fixing the outside temp sensor probably would not fix the HVAC problem. Just my opinion I don't know for sure
TurnThePage
North ID
Posted: 11/26/21 09:55am Link  |  Quote  |  Print  |  Notify Moderator
So... I've learned that there is only one sensor and it's the one I changed. I've also learned that it's semi-common for the wiring to this sensor to get damaged if there is even minor front damage. When this happened, my wife had hit a snow berm.
Also, this sensor absolutely does influence the HVAC system. In the winter it's not too bad, you can always get heat, usually too much, but you can deal with that by cracking a window.
Shouldn't be too difficult to find the damaged wiring once I get going on it, likely next spring.
Posted: 11/26/21 10:01am Link  |  Quote  |  Print  |  Notify Moderator
Lol. No mechanic work in the winter?
2017 Heartland Torque T29
enblethen
Moses Lake, WA
Posted: 11/26/21 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
You might want to look at Rockauto.com as they list two!
https://www.rockauto.com/en/catalog/ford........oning,cabin+air+temperature+sensor,14376
TurnThePage
North ID
Posted: 11/26/21 04:34pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the research and feedback. Those items are the cabin air temp sensors.
Just to be clear, we're talking about the ambient temp sensor that displays the outside temp and provides input to the HVAC system.
