RV.Net Open Roads Forum: Class A Motorhomes: Back up camera trouble
 > Back up camera trouble
two travelers
Smithtown, NY
Posted: 11/23/21 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Back up camera stopped working. Had the camera checked out by RV Cams and it appears to be working. Tech said I should look at the controller? The radio/dvd/cd and back up camera unit was replaced not to long ago.
We have a 2015 Winnebago Vista. Any ideas on where the controller might be found? Under the dash?
2oldman
So Cal
Posted: 11/23/21 06:32pm Link  |  Quote  |  Print  |  Notify Moderator
Whenever my camera stops working it's because the radio/display switch to 'see' the camera is off. That happens if the batteries are disconnected for any reason.
Land Yachters
Philadelphia
Posted: 11/24/21 09:59am Link  |  Quote  |  Print  |  Notify Moderator
My rear camera would stop working and intermittingly work for a bit and then stop again. Dealer first replaced wiring harness which seemed like a good start. I swore it was a bad ground. No joy. Same symptoms. Then they replaced screen in the dash. I didn't figure that was the issue...nope, same issue. Finally just replaced camera, and that fixed it. unsure if this is typical or what model camera it is. This is a 2018 Tiffin Allegro RED coach.
Land Yachters
Griff, Ali and Coco
Philadelphia, PA
2018 Tiffin 33AA
2018 Grand Cherokee
Yankee Clipper
Cairo, GA
Posted: 11/24/21 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
There is a 3-way controller on my rig. One video display (now JVC), with two side cameras and one back-up camera. The 3 to 1 controller is a white plastic gizmo under the video head, with a 12v power input, three video in, one out.
HTH
Yankee Clipper
2014 Winnebago Sightseer 33C on Ford F53 6.8l V10
2014 Honda CRV 4 down toad/Roadmaster Falcon2 with EvenBrake
TireMinder TPMS, Duke the overgrown Boxer mascot/lousy watch dog
Rosey the minidachshund resident Princess-in-Chief
