RV.Net Open Roads Forum: Truck Campers: range hood exhaust fan?
 > range hood exhaust fan?
notsobigjoe
southeast
Posted: 11/24/21 08:34am Link  |  Quote  |  Print  |  Notify Moderator
Has any one ever found a motor replacement that is considerably quieter than the normal exhaust motor in the range hood? I cook a ton when I fish and camp and after a while that fan will drive us out of our minds. I've taken some advice and tried to use the roof exhaust but it doesn't work all that well. I'm looking for just replacing the motor not the disassembly of the whole unit sort of a plug and play if there is such a thing. Thanks in advance, Joe
Bedlam
PNW
Posted: 11/24/21 08:46am Link  |  Quote  |  Print  |  Notify Moderator
Noise is a combination of motor, fan blades and exhaust chamber. The shape and size of the fan blades is typically the biggest factor. Maybe look at a variable speed control for your current motor?
Chevy Sonic 1.8-Honda Passport C70B-Host Mammoth 11.5-Interstate Car Carrier 20-Joyner SandViper 250-Kawasaki Concours ZG1000-Paros 8' flatbed-Pelican Decker DLX 8.75-Ram 5500 HD-Tank Urban Touring 150SE
AnEv942
CA
Posted: 11/24/21 09:05am Link  |  Quote  |  Print  |  Notify Moderator
YES, adding a PWM controller is about the best for reducing fan speed & noise and still maintain enough air flow to evacuate. I replaced our 18 year old motor and blade which was slightly quieter but it was adding the variable speed controller that made it not so atrocious.
Our camper projects page
Kayteg1
California > Nevada
Posted: 11/24/21 10:18am Link  |  Quote  |  Print  |  Notify Moderator
Fans will be always noisy.
Observe that high-end household hoods use blowers instead. Those are much quieter, but rebuilding factory hood to accommodate blower would make whole project.
notsobigjoe
southeast
Posted: 11/24/21 10:58am Link  |  Quote  |  Print  |  Notify Moderator
OK, I can definitely replace the fan blade and run the PWM controller.
How about these?
https://www.amazon.com/Controller-Motor-Speed-Pump-Blower/dp/B075FN4H37/ref=sr_1_6?crid=12YDMCUP1AICP&keywords=pwm+fan+controller+12v&qid=1637776370&sprefix=pwm+fan+controller%2Caps%2C216&sr=8-6
https://www.amazon.com/Wadoy-D-Bore-D-bore-Replacement-Ventline/dp/B07V687K5B/ref=sr_1_25?keywords=replacement+fan+blade+for+RV+range+hood&qid=1637776613&sr=8-25
This is what's on there.
https://www.amazon.com/Motor-Blade-Kit-Range-Hood/dp/B004882JOA/ref=sr_1_33?keywords=replacement+fan+blade+for+RV+range+hood&qid=1637776690&sr=8-33
corvettekent
Marysville, WA
Posted: 11/24/21 11:01am Link  |  Quote  |  Print  |  Notify Moderator
I installed a 6" computer fan and it is very quiet now. Make sure that the one you get is 12 volts.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Turnover Ball, Companion Hitch.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT and four 6 volt batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
ticki2
NH
Posted: 11/24/21 11:37am Link  |  Quote  |  Print  |  Notify Moderator
I did the same thing . It is not as powerful as the original but only draws about 0.5 amps instead of 3+ amps like the original . It gets rid of the steam from making coffee or pasta on the stove and is very quiet .
'68 Avion C-11
'02 GMC DRW D/A flatbed
2oldman
NM
Posted: 11/24/21 01:27pm Link  |  Quote  |  Print  |  Notify Moderator
I put a rheostat on mine. At full bore it darn near sucks the flame out.
AnEv942
CA
Posted: 11/24/21 02:36pm Link  |  Quote  |  Print  |  Notify Moderator
The DC controller linked is only rated at 1 amp max. Not positive I remember correctly but seems our little can motor draws 1 1 /2+ amps. Just verify
The motor linked as what you have, looks like an AC motor?
Itchey Feet
Wyoming
Posted: 11/24/21 05:18pm Link  |  Quote  |  Print  |  Notify Moderator
I have also installed computer fans in our TC as well in our ORV trailer.
My feet are fine as long as they are traveling.
