RV.Net Open Roads Forum: Tech Issues: Portable battery Charger
 > Portable battery Charger
Lakejumper
Northern California
Posted: 11/24/21 07:00pm Link  |  Quote  |  Print  |  Notify Moderator
Can a RV battery be charged with a portable charger while plugged into shore power?
Lakejumper
2016 Winnebago Vista LX 30T
2012 Chevy Equinox
Skibane
San Antonio, TX
Posted: 11/24/21 08:13pm Link  |  Quote  |  Print  |  Notify Moderator
Sure!
Even if the battery charger in your RV's power converter is supplying some charging current to the battery, you can still connect a portable charger to the battery to charge it faster.
However, there is a limit to how fast you can charge a battery - particularly if it's the lead-acid variety. At some point, some of the charging current gets converted to heat, instead of charging the battery. Result: Excessive water loss, and possibly damage to the battery.
Most lead-acid batteries can accept a lot more charging current during the early portion of the charging process. As they gradually recharge, their ability to absorb charging current gradually tapers off.
For this reason, using several battery chargers may be more effective early in the charging process. Later on, just one battery charger may be sufficient to supply all the charging current the battery can accept.
time2roll
Posted: 11/24/21 10:39pm Link  |  Quote  |  Print  |  Notify Moderator
Yes
675w Solar pictures back up
valhalla360
No paticular place.
Posted: 11/25/21 12:12am Link  |  Quote  |  Print  |  Notify Moderator
Yes, but there is a limit to the amps a battery can absorb, so typically, there is no reason to bother.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Lakejumper
Northern California
Posted: 11/25/21 08:18am Link  |  Quote  |  Print  |  Notify Moderator
Thank you.
Anza-Borrego Desert SP area
Posted: 11/25/21 11:00am Link  |  Quote  |  Print  |  Notify Moderator
Lithium batteries can accept fast charge. One of their advantages.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Horsedoc
Dixie --- N. Georgia
Posted: 11/25/21 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
I have had two Schumacher chargers over the years. I don't recall models but both would shut down when the battery was fully charged.
horsedoc
2008 Damon Essence
2013 Jeep Sahara Unlimited
Blue Ox tow
Posted: 11/26/21 04:55am Link  |  Quote  |  Print  |  Notify Moderator
I would suggest using a "Smart" type charger (I used a Deltran Battery Tender 2/20/70 amp model (20 was for battery charging then it dropped to tender) you do need to monitor it as it will not return to "Charge" automatically.. 70 is for jump starting and did not work well for me).
The most likely "worst case".. one of the chargers may refuse to go into "Battery charge" because it senses the other charger and thinks "Batteries full"
Other worst case.. already covered above.
jaycocreek
Idaho
Posted: 11/26/21 08:15am Link  |  Quote  |  Print  |  Notify Moderator
I use a Noco Genius smart charger also when boondocking and running the generator..
valhalla360
No paticular place.
Posted: 11/27/21 12:58am Link  |  Quote  |  Print  |  Notify Moderator
But Lithium are much more sensitive to bad charge methods...I would be hesitant to randomly hook up multiple charge sources.
