RV.Net Open Roads Forum: Tech Issues: Multimeter recommendation?
 > Multimeter recommendation?
Page of 6
Kansas couple
Minnesota
Posted: 11/25/21 06:40am Link  |  Quote  |  Print  |  Notify Moderator
I'm looking to buy a multimeter, as my rig's refrigerator doesn't work on electric but still works on gas. There is power to its outlet (of course, that would be too easy of a fix..) and I know my next steps will involve going to the circuit board. I'm looking at the Klein Tools multimeters they sell at Home Depot. Noticed the CL 390 can measure DC amperage. Would this be something to have, or is measuring DC current not that important? If not, then I'd go with one of the less-expensive models. I'm open to thoughts and input. Thanks!
Seon
Lake Camanche, CA
Posted: 11/25/21 06:44am Link  |  Quote  |  Print  |  Notify Moderator
Buy a cheap Harbor Freight meter if that's all you're doing.
https://www.harborfreight.com/7-function-digital-multimeter-63759.html
larry cad
ohio
Posted: 11/25/21 06:55am Link  |  Quote  |  Print  |  Notify Moderator
Buy the best you can afford. Frequently, when you have an electrical problem, others here can suggest tests to be made to find the problem. You may not know how to do the tests but others can guide you through it. Meter readings are essential for a rapid solution. No meter, no solution.
Also, in the course of doing the above, you will learn tricks to put in your memory bag.
P.S. having an amp meter can be very helpful.
Our Travel Blog
Roger10378
Goodrich, MI.
Posted: 11/25/21 06:58am Link  |  Quote  |  Print  |  Notify Moderator
How much amperage does it measure? Most low to mid priced meters will only measure small amounts of amps so that function is largely useless. As noted above just buy something cheap as it will do more than most of us need.
2005 Cardinal 30TS
2007 Chevy 2500HD D/A
fj12ryder
Platte City, MO
Posted: 11/25/21 07:15am Link  |  Quote  |  Print  |  Notify Moderator
Is the meter a clamp-on amp meter? I rarely use my amp meter, but it's very handy to have. The Harbor Freight meters will do a decent job for simple continuity and voltage testing, but nothing sophisticated. The level ability of the meter should match your level ability. [emoticon] For simple continuity and voltage testing, a HF cheapo will work as well as a $150 Fluke. But if you need more...
Howard and Peggy
"Don't Panic"
KD4UPL
Swoope, VA
Posted: 11/25/21 07:26am Link  |  Quote  |  Print  |  Notify Moderator
DC amperage is very hand around an RV where nearly everything is DC. Is this a clamp on amp meter or do you have to insert the probes into the cirucit? I prefer the clamp style as it's much easier to use and will read much higher currents. If you ever need to measure DC current from a solar array or to an inverter you will appreciate the clamp DC meter.
I wouldn't buy anything electrical from HF. If you're going to invest in a tool invest in a good one. Fluke is the top of the heap but I'd take Klein, Southwire, or Ideal any day.
Keep in mind, with cheap HF meters, you will have live electrical power flowing thur this device. A cheap meter that blows up in your hand is a really bad deal.
Kansas couple
Minnesota
Posted: 11/25/21 07:39am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the comments!
I didn't mention this in my original post, but I am closing on a house next week so I figure even if I didn't have the refrigerator issues, a good multimeter will still be very useful.
Roger--according to the info on Home Depot's page, the 390 can measure up to 400 amps DC.
fj12ryder--it is a clamp-on meter. My electrical knowledge is a bit limited but I do know I want the ability to measure current in addition to volts and resistance.
otrfun
On The Road
Posted: 11/25/21 07:54am Link  |  Quote  |  Print  |  Notify Moderator
We have Fluke and Amprobe clamp-on meters we use primarily for accurate current measurements. For quick, general troubleshooting we generally use one of 3 or 4 red Harbor Freight VM's we picked up for free a few years ago (currently sell for $6.99). DC volts read to .xx and they're reasonably accurate.
There are a number of inexpensive clamp-on ammeters with test leads for measuring DC and AC voltage, that also have capability to measure both DC *and* AC current (using the clamp-on, not the test leads), available on Amazon. IMO these units are the best, all-around, single device for general RV troubleshooting.
Boon Docker
Posted: 11/25/21 07:57am Link  |  Quote  |  Print  |  Notify Moderator
That "390 meter" from Home Depot would serve you well.
MNRon
Tennessee
Posted: 11/25/21 08:10am Link  |  Quote  |  Print  |  Notify Moderator
I’m an EE and have used lots of lab equipment for my job. At home I have a couple of DVMs and even an old analog one with a clamp-on current measurement capability. With that said, easily 80% of the measurements I’ve taken at home or RVing are simple voltage measurements (both AC and DC); the other 19.99% are resistance measurements (usually just looking for continuity); and the last 0.01% are current readings. My recommendation is to get a voltmeter and carry it, if it’s a cheap one it will probably do everything you ever desire; if you buy a nice expensive Fluke you’ll be able to admire it and be proud of it, but RV use probably won’t distinguish between the two.
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
Page of 6
