RV.Net Open Roads Forum: Tech Issues: Multimeter recommendation?
 > Multimeter recommendation?
Page of 6
Thermoguy
Graham, WA
Posted: 11/28/21 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
There are some good points made on this thread - but some that need definite clarification and correction.
Fluke is no longer made in America. I think they switched to assembled in America a few years back now I believe it is designed in America. Not saying they are not the gold standard, which they are. They are the most reliable and safest, but you pay for that - but is an extra $50-$100 really that much more?
Next, your value brands like Craftsman and Radio Shack, aren't really comparable to HF. They were made (designed by) Extech, which is considered a mid level brand. So, much higher than the Amazon or HF cheap knock off made in some factory for as cheap as they can.
Now, why does this matter - they points that are the most important on this thread. They only thing between you and what you are measuring is the meter and the leads you are using. If you use something made by a company that is just trying to make the cheapest thing out there, are you really safe? Now, if you are only reading DC batteries, and the DC in your trailer, then I guess safety is not a thing. Take 2 wires connected to a light bulb and you are just as safe. But, you are you measuring 120V - 240V household, or a 30-50 amp pedestal, do you want to rely on the cheapest thing made, or do you want to spend an extra $50-$100 to make sure you don't get shocked or worse. Your probably only buying 1 so just spend a little more for an average or better meter.
Next, accuracy and reliability. I know when I measure my batteries, I want to know what they read. Is my battery 12.7v or 12.1v. Do I measure, come back 2 minutes later and its changed by 1 volt? I'm sure there are other examples where accuracy matters. But, if you don't care about a good reading, why even buy a meter? There was an entire thread on tire pressure gauges. This is different, because a gauge is usually off but consistent. A meter that is off can be high today and low tomorrow. It can be off by tenths or by an entire point. It will be inconsistent for every reading. What do you consider is acceptable and do you trust the manufacturer that designed it and had it made in that factory in China. Is it made in China or Taiwan?
I'm not advocating for Fluke or any specific brand, just saying be careful. I think the OP purchased Klein, which is a great middle of the road brand. As I said before, if they make electrical test tools, this is much better than a company that is trying to sell the cheapest thing they can have made.
CA Traveler
The Western States
Posted: 11/28/21 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
Good points above. Most RVs should not be probing a 120V or 240V due to the potential danger. Especially a pedestal while holding the metal cover open with one hand or standing in a damp area due to a nearby faucet or drain.
2014 Grand Cherokee Overland
Bob
ktmrfs
Portland, Oregon
Posted: 11/28/21 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
well, since there are lots of 120V circuits in an RV, and based on issues that have come up from posts, 120V power issues are common enough to need troubleshooting at times, brush up on best practices for safety when working on line circuits.
And make sure that ANY test device you use on such circuits carries at least a CATII 300V rating, CATIII 600V is better.
That will provide some safety in case of a mistake.
2011 Keystone Outback 295RE
2112
Posted: 11/28/21 08:07pm Link  |  Quote  |  Print  |  Notify Moderator
We use flukes at work that require annual calibration as well. They are returned from cal lab with an official cal report documenting measurements recorded prior to any adjustments. In the 33 years I have reviewed the fluke cal data they have never been out of cal on voltage. Some of these meters are 15 years old or older. Amperage is a different story. Amps are sometimes a little off in the lower ranges and require adjusting.
About 6 years ago we bought 4 EXTECHs for some reason. I guess part of a cost savings plan. All 4 have came back from cal lab spot on on all measurements on all functions for the past 5 years.
2013 KZ Durango 2857
CA Traveler
The Western States
Posted: 11/29/21 08:20am Link  |  Quote  |  Print  |  Notify Moderator
Plugging the RV into a 20A GFCI circuit can provide some additional protection when looking for a problem. I've never seen a 30A or 50A GFCI plug in a CG but they probably exist.
Also, I've recommended numerous times to plug into a 20A GFCI plug and turn various appliances on/off to check for a ground fault condition. Do this at least once if not on some periodic basis.
OkieGene
oklahoma city
Posted: 12/15/21 06:55pm Link  |  Quote  |  Print  |  Notify Moderator
Well how about that? I kept thinking I had a Fluke. I kept digging around in all the toolboxes in my garage.
Finally found it. It's a Fluke model 77, series 2.
I got it used, due to a screwy situation, back in 1991-ish. So this old girl is 30 years old or a few more years older.
Off to get an Eveready Energizer 9 volt Lithium battery and will fire this old girl up and see what happens.
Tom_M
New Hope, MN
Posted: 12/16/21 06:21am Link  |  Quote  |  Print  |  Notify Moderator
Here's my Fluke 77 that I have had for decades. An incandescent lamp tipped onto it and after about 30 minutes this was the result:
Tom
2005 Born Free 24RB
170ah Renogy LiFePo4 drop-in battery 400 watts solar
Towing 1978 VW Bug convertible
Minneapolis, MN
Matt_Colie
Southeast Michigan
Posted: 12/16/21 07:52am Link  |  Quote  |  Print  |  Notify Moderator
Tom_M,
That is a very sad picture.
I have two 77s one is not a series anything because they hadn't even started that when I got it. It is old and has had to have the switch patched, but I still love it.
The 77 series 2 is the one I carry in the coach.
I also have a 20yo 87 and a Bell probe that live in a case and only goes out on paying jobs.
Oh yeah, and a collection of throw-away meters so I have something I don't worry about getting damaged.
Matt
Matt & Mary Colie
A sailor, his bride and their black dog (one is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
CA Traveler
The Western States
Posted: 12/16/21 08:01am Link  |  Quote  |  Print  |  Notify Moderator
I have a 77 Fluke dates to the 80's. Made in the USA.
WinMinnie02
NJ
Posted: 12/20/21 07:02pm Link  |  Quote  |  Print  |  Notify Moderator
OP do you know what you are looking for to determine why your refrigerator is not working on electric? Are you trying to determine if it is the fuses? Could it be the Thermistor? Klein tools 600v for $55 is fine from Home Depot, used it last few years home, auto, and RV.
Page of 6
