RV.Net Open Roads Forum: Tech Issues: Multimeter recommendation?
 > Multimeter recommendation?
Page of 6
OkieGene
oklahoma city
Posted: 11/26/21 03:21pm Link  |  Quote  |  Print  |  Notify Moderator
theoldwizard1 wrote:
CA Traveler wrote:
For a meter, decent middle of the road clamp meter, Uni-T UT210E.
Thanks! Just ordered one.
Boon Docker
Posted: 11/26/21 05:52pm Link  |  Quote  |  Print  |  Notify Moderator
I have the UT204A, it is an excellent meter. The UT210E is comparable to the UT204A.
C Schomer
Pueblo West, Co.
Posted: 11/26/21 11:29pm Link  |  Quote  |  Print  |  Notify Moderator
Here it is on Amazon. https://www.amazon.com/Klein-Tools-CL390-Electronic-Resistance/dp/B08DTDCG7T/ref=asc_df_B08DTDCG7T?tag=bingshoppinga-20&linkCode=df0&hvadid=79920843356084&hvnetw=o&hvqmt=e&hvbmt=be&hvdev=c&hvlocint=&hvlocphy=&hvtargid=pla-4583520392045748&psc=1
That's dirt cheap for everything it does but I bet it's a throwaway meter if it ever goes out of cal. I have an old UEI throwaway but it's nice to have the DC clamp sometimes. Craig
JimK-NY
NY
Posted: 11/27/21 05:55am Link  |  Quote  |  Print  |  Notify Moderator
I RV camped full time for a couple of years and have spent hundreds of nights out since then. Never once have I needed a multimeter. Even at the house, a 60 year old, low cost multimeter is all I have ever needed. At one time I had several canvas bags with tools and supplies. I have cut that way back to just a handful of basic tools. I could do 90% of the work I have needed over the years with just a multitool.
StirCrazy
Kamloops, BC, Canada
Posted: 11/27/21 08:58am Link  |  Quote  |  Print  |  Notify Moderator
fj12ryder wrote:
$50 is cheap? We definitely have different definitions. [emoticon]
that same one is probably 150 up here. I thiught it was a good deal, and ya I do concider 50 cheep for a quality tool.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
MFL
Midwest
Posted: 11/27/21 09:17am Link  |  Quote  |  Print  |  Notify Moderator
JMO...there are several definitions of cost, cheap throw away, lower priced, middle priced, and expensive. I usually try to buy the best product (expensive), with the features I need, for the lowest price.
Jerry
Gjac
Milford, CT
Posted: 11/27/21 10:26am Link  |  Quote  |  Print  |  Notify Moderator
I guess everyone looks at things differently. I use a multimeter all the time working on a 25 year old MH. Maybe I am not as careful as some but one I ruined while checking the fuel pump on my genset with gas. Another got left out in the rain. If these were $150 Flukes I would be very upset but they were free from HF. They do everything I need them to do and they have an adjustment inside that you can adjust the voltage with a pot to match a voltage setting with a good meter. The original one I got from HF is 17 years old and I added better leads from Radio Shack and still works fine.
Cummins12V98
on the road
Posted: 11/27/21 10:47am Link  |  Quote  |  Print  |  Notify Moderator
Jerry
YEP and I bet most of your tools are still in service from years past.
I have a Fluke that is US Made. I have no idea how to use many of it's functions but hey they are there if needed. Same model the Commercial Electricians used on my jobs years ago.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Gdetrailer
PA
Posted: 11/28/21 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
Cummins12V98 wrote:
Jerry
I have used Flukes at work, they are no better than any other meter (even cheap HF) if you have not or never had them calibrated to a known standard. At work, all devices like meters, torque wrenches and such were required by the QA department to be tested and calibrated every yr.
Not all meters can be calibrated or will be able to hold a calibration to specs, that is where Fluke comes in and are able to be calibrated and do a good job holding that calibration.
But for HOME or even general electrician or mechanic use, a Fluke is not needed at all. You are not manufacturing to tight tolerances and general electrical work does not need pin point accuracy. Now if you were trying to troubleshoot an amplifier circuit where .1V can mean difference of working or not, than perhaps a Fluke or a bit better quality than HF would be a better choice.
For RV and auto use calibration to a known standard is not needed and pretty much any cheap meter that can give a consistent reading will suffice.
I have a nice 35yr old RadioShack auto range DVM which works fine and a bunch of cheapo give away HF DVMs laying around.. Those cheap HF DVMs are plenty accurate for 12V and 120V/240V work and I have not noticed any of those being inaccurate with each other (they all agree with each other).
$5-$6 HF meters are fine for the use the OP will be using it for.
ktmrfs
Portland, Oregon
Posted: 11/28/21 01:35pm Link  |  Quote  |  Print  |  Notify Moderator
Gdetrailer wrote:
Cummins12V98 wrote:
Jerry
One big advantage of the fluke 73 or similar or the Tek TX series of DMM's is that they extremely robust. I've dropped the TX3 from 25ft onto concrete, several times, no damage. Flukes I have are similar.
And they are really hard to damage with an incorrect hookup. Hook the MA range up across a 12V trailer battery and all that the 300+A short circuit current will do is a popped fuse, unlike some others that even a fuse won't protect.
And the leads are designed for some UL spec's that makes it highly unlikely to ever expose you to line voltage.
Both are tested and calibrated in production with NIST traceable equipment, so out of the box you know they are well calibrated, but as mentioned for precision work they need periodic test. But I'd say the likely hold cal better than el chepo's.
I could go on more, as I was involved in the design of some of these meters, they are industrial grade, targeted at industrial users. Kinda like snap on vs. harbor freight. Each serves a specific market well.
I will say they are more accurate than what the vast majority of users for RV or home applications will ever need. Products from Klein tools and similar are more than accurate enough, robust enough and much lower cost.
so, for an occasional user that only needs a few functions for qualitative measurements, the Fluke and old Tek TX meters are probably overkill, depends on what is important to you.
2011 Keystone Outback 295RE
Page of 6
