RV.Net Open Roads Forum: Travel Trailers: Getting my trailer settled for the winter
 > Getting my trailer settled for the winter
mkenyon2
Lebanon, PA
Posted: 11/26/21 08:05am Link  |  Quote  |  Print  |  Notify Moderator
First things first, get it off the ground a bit. Laid a few pavers to get it out of the dirt.
And here it's parked. Will put the other 2 stabilizers down to take some weight off the suspension.
MK out of PA and My Wifey
TV: 2011 Ford F150 SuperCrew 4WD (V6 3.5L/213)
Trailer: 2013 Heartland Trail Runner 25 SLE
We've only camped in 2 states? Quick, pack the trailer we have to CAMP!
MFL
Midwest
Posted: 11/26/21 09:04am Link  |  Quote  |  Print  |  Notify Moderator
Just my experience, but with long term temp extremes, I've noticed the ground will shift. I would not make all 4 corners solid. When the ground freezes hard it can raise the blocks/jacks differently.
I'd add about 5 psi to tires, over max sidewall for Winter storage. Your suspension should not need to be unloaded for storage, even though some may say to block tires/wheels up.
JMO, FWIW
Jerry
spoon059
Just north of D.C.
Posted: 11/26/21 09:23am Link  |  Quote  |  Print  |  Notify Moderator
I wouldn't do this. If you get a flat tire, that will transfer your weight onto your jacks, which can damage your jack or your frame.
The suspension is made to handle the weight. The stress on the suspension is far greater when you are traveling down the road and hitting bumps and shifting weight.
2015 Ram CTD
2015 Jayco 29QBS
kellem
Shenandoah valley,VA
Posted: 11/26/21 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
I park in gravel over the winter and have done so for 30+ years without any issues. I've not erected the stabilizers though but see nothing wrong with your regime
Sometimes we overthink.
GrandpaKip
Flat Rock
Posted: 11/26/21 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
Stabilizers are not meant to take weight off the suspension. That’s a good way to twist the frame.
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
bguy
The Rock
Posted: 11/26/21 09:41pm Link  |  Quote  |  Print  |  Notify Moderator
Just the nose jack for me with a couple planks under the tires to spread the load on the stones.
2011 Ram 1500 Quad Cab, 4x4, 3.55, HEMI
2009 TL-32BHS Trail-Lite by R-Vision
JBarca
Radnor, Ohio, USA
Posted: 11/27/21 05:34am Link  |  Quote  |  Print  |  Notify Moderator
Good job on getting the tires out of the grass/dirt for long term storage.
I agree with the others, for overwinter storage leave the stabilizers up. These campers frames can bend easier then one thinks. The suspension can handle the weight.
I agree to make sure you have full tire pressure at the side wall cold pressure.
Something to consider if you plan to keep the camper a good long time or even a few years, cover the tires with a light/white tire covers. The UV sun damage on the tires is for sure there. Consider getting a breathable camper cover and read up on how to add extra rip protection for hard sharp covers before putting it on. Having the camper under cover/covered will make it last a lot longer from less sun damage to the plastics/vinyl/roof and help stop leaks starting in degrading sealants on the roof and siding.
Happy camping come next season.
John
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
mkenyon2
Lebanon, PA
Posted: 11/29/21 10:48am Link  |  Quote  |  Print  |  Notify Moderator
As an aside, I don't have all the weight on the jack stands, barely any. And I have a cover on now, breathable ADCO cover. Pics will be forthcoming.
Planeteer
N. IN
Posted: 12/03/21 09:05am Link  |  Quote  |  Print  |  Notify Moderator
I did the same thing with pavers this year. Glad I read this though, because I think I'll go chock my wheels better and raise my stabilizers for the winter.
Thanks!
2021 Gulf Stream 197BH
