RV.Net Open Roads Forum: General RVing Issues: Cause and effect?
 > Cause and effect?
Cummins12V98
on the road
Posted: 11/26/21 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
Recently I filled my large outer propane tank. When re connection I heard a hiss and determined the crimp was leaking for the large connector. I found Mr heater hose in 12" but when looking at the end that screws into the transfer device it did not have a check valve as the OE did. I looked a few places and finally stopped at a Propane Delivery Company that had parts also. The Manager said no need for the check valve. OK so I installed the hose and all seemed well.....UNTIL.
We stayed at a rest area last night on our trip South and it was COLD up near Barstow, CA. I fired the gen up and then it died. I tried a few times and started to run then died every time.
OK now what had changed??? I had the outside tank open and the inside closed as usual so I never completely run out. I went outside and turned the transfer switch to the inside tank and opened it up leaving the outside tank open. Went inside and sure enough the gen fired and stayed running.
Raised the Satellite Dish and turned on the furnace and had a nice evening staying warm and watching NETFLIX. Well I fell asleep and around 12:30 am the gen stopped. I just went ahead and fell back asleep and woke at 5am thinking OH SHITE I bet both tanks are empty and my dish is sticking up. I had thoughts of having to disconnect and find propane.
Then my foggy brain kicked in and checked the tanks. Sure enough the inside tank ran out and the outside was still full even tho the transfer should have switched. So swapped the tanks and opened the inside tank and WA-LA the gen fired right up stayed running and allowed me to store the rooftop dish.
So now can someone please explain what the lack of a check valve has to do with the gen not staying running???
Opposite end of my finger has the built in check, new hose does not.
FYI the Mr Heater hoses are nice quality and US Made.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
bgum
South Louisiana
Posted: 11/26/21 02:58pm Link  |  Quote  |  Print  |  Notify Moderator
The propane dealer should have been able to make you a new hose with your parts. All it would have taken was a short piece of new hose or just a new crimp on your hose.
rk911
DuPage County
Posted: 11/26/21 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
how are you getting netflix on your sat dish?
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
Cummins12V98
on the road
Posted: 11/26/21 05:24pm Link  |  Quote  |  Print  |  Notify Moderator
Actually we were not watching NETFLIX. But we do go thru the Hopper to watch NETFLIX when we have internet connection.
Cummins12V98
on the road
Posted: 11/26/21 05:25pm Link  |  Quote  |  Print  |  Notify Moderator
Did you read my post?
rk911
DuPage County
Posted: 11/26/21 05:45pm Link  |  Quote  |  Print  |  Notify Moderator
tnks
Lantley
Ellicott City, Maryland
Posted: 11/26/21 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Without the check valve what keeps the gas from just flowing between the 2 tanks and just equalizing vs. flowing to the appliances? Especially if the appliance is off
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
Dutch_12078
Winters south, summers north
Posted: 11/26/21 07:13pm Link  |  Quote  |  Print  |  Notify Moderator
The ACME fitting on the hose may have a built in high flow valve that shuts off if it thinks there's a major leak in the system. Sometimes those valves trip when the cylinder service valve is opened too fast. Try shutting the service valve off, loosening and retightening the Acme fitting, and then opening the valve slowly to see if that works better.
Dutch
2001 GBM Landau 34' Class A
blofgren
Surrey, B.C.
Posted: 11/26/21 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
Doesn't the automatic transfer valve prevent this? Very interested in this thread because I plan on replacing my propane pigtails in the spring.
2013 Ram 3500 Megacab DRW Laramie 4x4, 6.7L Cummins, G56, 3.73, Maximum Steel, black lthr, RAM 20k sliding hitch, Retrax, Linex, and a bunch of options incl. cargo camera
Cummins12V98
on the road
Posted: 11/26/21 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
Bottom line my gen starts and runs with the line that has the check valve and does not stay running on the new line without the valve.
My cooktop and furnace both work on either line.
 > Cause and effect?
