RV.Net Open Roads Forum: Class A Motorhomes: Stuck Countertop Extender
 > Stuck Countertop Extender
genemcdole
AZ
Posted: 11/26/21 06:05pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Folks, I have a 2005 Itasca Horizon 40AD. In the galley it has a counter top extension that pulls out with additional cupboard storage built into it. It appears that the cable for the release latch has come loose from the latch mechanism and I am unable to pull the unit open. What would I need to do to gain access to the latch mechanism so that it can be manipulated manually and then repaired? At this point I have not yet been able to even locate where the latch is mounted but it is obviously somewhere behind the sliding portion of the unit.
Thanks! Gene from AZ
CA Traveler
The Western States
Posted: 11/26/21 07:56pm Link  |  Quote  |  Print  |  Notify Moderator
Is there any access by removing drawers, etc? Adjacent cabinet access like access at top or bottom? Something removal? Lights, cameras, mirrors helpful? Kid with small arms? Trim removal? Use force and screws pull out?
2014 Grand Cherokee Overland
Bob
jdc1
Rescue, Ca
Posted: 11/27/21 10:17am Link  |  Quote  |  Print  |  Notify Moderator
Pull the rear panel off.
cbeierl
Nashua, NH
Posted: 11/27/21 11:42am Link  |  Quote  |  Print  |  Notify Moderator
On my 2005 Vectra 36RD the side panel (beside the sofa) pulls off (it's held on with clips). I don't know if you can actually get it off without removing the sofa, however.
Chris Beierl
2005 Winnebago Vectra 36RD
genemcdole
AZ
Posted: 11/27/21 04:15pm Link  |  Quote  |  Print  |  Notify Moderator
I am thinking this is the ticket. There is a fake cabinet door beside the sofa. I don't think I will be able to access it it without removing the sofa though. Removing the only drawer in the unit only allows me to see part of the release cable run but not the latch itself.
Looks like the sofa is on its way out. Thanks for the advice folks!
