RV.Net Open Roads Forum: Class C Motorhomes: Wobbly loose mirror arm
 > Wobbly loose mirror arm
pcallanan
CA
Posted: 11/27/21 12:05pm Link  |  Quote  |  Print  |  Notify Moderator
hello
I have a mirror arm on a Ford 450 that is very loose where the mirror arm meets the housing on the door. the mirror is made by Velvac.
There's a cap on the bottom which says not to remove it and that there are no serviceable parts.
Any ideas on how it can be tightened?
Thanks
bobndot
Posted: 11/27/21 01:24pm Link  |  Quote  |  Print  |  Notify Moderator
Not sure which mirror you have. Electric or non elec e Velvac.
This breakdown might be helpful.
https://www.velvac.com/sites/default/fil........l_and_replacement_of_2030_components.pdf
pcallanan
CA
Posted: 11/27/21 03:01pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the post. Mine is an electric for a class C.
I removed the assembly from the door frame but there doesn't look like there's anything to tighten. The most logical place would be under the post where the "no serviceable parts" cap is...
IAMICHABOD
Sunny So Cal
Posted: 11/27/21 05:05pm Link  |  Quote  |  Print  |  Notify Moderator
Under that cap you will see a pressed on washer that holds the spring on the cast iron post,these will fail as mine did and explode as referenced in this article,there is no way to tighten it,only replacement.
Former El Monte RV Rental
Buying A Rental Class C
pcallanan
CA
Posted: 11/27/21 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks - that's very useful information.
Kennyg
Green bay, Wi 54303
Posted: 11/28/21 08:29am Link  |  Quote  |  Print  |  Notify Moderator
I also own a e450 with the driver side mirror wobbly as you described. In fact, the arm fell off as I exited a toll booth. I called ford who is NOT the mfg or installer It was Velvac. Called them and they replaced it for only $247. Two years later the same thing was occurring and again I called Velvac. I also sent pictures of the mirror. This time they sent replacement at no cost!! However, the packing slip did indicate that this time the price was over $400. Give them a call and also send pictures! AND it goes without saying, be businesslike. Good luck.
Kennyg
IAMICHABOD
Sunny So Cal
Posted: 11/28/21 01:53pm Link  |  Quote  |  Print  |  Notify Moderator
If you have to replace them just look under each mirror to get the correct replacement.
When mine exploded I was only 7 days from a long trip,luckily Velvac shipped express for more money.I also replaced the other mirror,just in case.
Left Mirror:
Right Mirror:
Velvac mirrors are side specific.
ron.dittmer
North-East Illinois
Posted: 12/01/21 07:01am Link  |  Quote  |  Print  |  Notify Moderator
A common cause for long Velvac arms coming loose or broken, is a child hanging on them. They can't resist the temptation. I once caught a child grab an arm and about to hang his weight but I stopped him in time. Since then, I always fold the arms in when parked.
2007 Phoenix Cruiser model 2350, with 2006 Jeep Liberty in-tow
IAMICHABOD
Sunny So Cal
Posted: 12/01/21 02:30pm Link  |  Quote  |  Print  |  Notify Moderator
While children hanging from them may cause some of them,the most common reason is water intrusion.The water comes in and sits in the washer that holds the spring on the pot metal shaft corroding it until it breaks under the pressure of the spring.
I got this from the tech at Ryder Truck Rental,at the time mine broke that is where you bought them.It seems that the fleet was washed a lot and there was evidence of water in the arms and shaft on the ones that failed,as was mine.
SJ-Chris
San Jose, Ca
Posted: 12/09/21 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
How easy/hard is it to replace the entire arm and mirror? I have one that bends in when the RV is going 65mph and there is some headwind.
Thanks!
Chris
San Jose, CA
Own two 2015 Thor Majestic 28a Class C RVs
