RV.Net Open Roads Forum: Class A Motorhomes: Better handling
 > Better handling
donkeydew
OR
Posted: 11/28/21 07:30pm Link  |  Quote  |  Print  |  Notify Moderator
try relaxing your grip on the wheel and look a little farther ahead and it may solve your problem. it is quite common for first time owners to over react just relaxing and not fighting it helps a lot.
way2roll
Wilmington NC
Posted: 11/29/21 06:53am Link  |  Quote  |  Print  |  Notify Moderator
MountainAir05 wrote:
Might want to read this on the Chf. Have run across some that did this and the cost for repair was not nice. If you are having an issue then fix it the right way and enjoy it far longer and a nicer ride. front end alignment and correct air pressure will make a big difference. You might add that tires can and do cause a lot of handing issues.
CHF fix
Not what I would consider a reliable article considering it's from a company selling their own trac bars. LOTS of people have done the CHF with amazing results and zero issues. I did it on both my previous MH's and it almost totally eliminated truck push and wander. You also want to start with proper PSI which requires loading your rig for travel and setting PSI to the tire manufacturer's chart. OP - you said you are new to the Class A world, so you may want to have some realistic expectations on how Class A's - especially gassers - ride and handle. Not to say there aren't things you can do to improve ride, but I would start with free things before I'd throw a bunch of money at it. Alignment and proper psi should be done regardless of your issues.
Alex and Tee
Jacksonville , FL
Posted: 11/29/21 09:21am Link  |  Quote  |  Print  |  Notify Moderator
While driving cross country and also being a first timer I was able to anticipate the “push” from passing big rigs and steer slightly into it as the front of their vehicle approached mine. I had more issues with the surprise gusts of crosswinds that were occasionally encountered. That said, I agonized when we first purchased whether or not to add a Safety Plus or not and decided to see how it handled first before dropping $800-$1000. As of now I’m happy I kept the money in my pocket.
Alex & Teresa
2022 Allegro Open Road
2021 Colorado 4x4
Lancslad
SE VA
Posted: 12/12/21 03:07pm Link  |  Quote  |  Print  |  Notify Moderator
Find a good truck shop to do an alignment. Then do the CHF. Then if you need to open your wallet. I did the first 2 and can drive with 1 hand!!
2011 FR Georgetown 337DS
2003 Dodge Dakota Towed
AllegroD
Outdare
Posted: 12/12/21 06:31pm Link  |  Quote  |  Print  |  Notify Moderator
There are a few threads on this @ Tiffin RV Network
 > Better handling
