RV.Net Open Roads Forum: Tech Issues: Furnace gas valve
 > Furnace gas valve
Bob E.
Canonsburg, PA
Posted: 11/28/21 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
JBarca wrote:
Bob E. wrote:
My furnace is an older hydro flame 8531-II. the gas valve is not functioning so I was going to order a new one. But it appears that part number 31155 is no longer available. Does anyone know if the gas valves are more or less the same? I found one that looks similar except the propane inlet fitting is on the side rather than the back. Mine actually has a couple of fittings that connect to the propane line in the side. So I’m wondering if this alternate part would work.
Hi,
I'm not sure where you found the Atwood 31155 aligns to the Atwood 8531-II.
From the 2015 service manual, they call out 38607 for the 8531-II. And and the 38607 is now obsolete and I found the trail that 31150 is what replaces it. The 2015 manual says the 31155 fits the 85XX-LD furnace.
I have bought and installed 2 of the 31150 this year with the last installed one in October. And ordered 2 more for stock last week.
See if this will work on your setup. Pics below.
The 31150 looks like this
A bench leak test on the new one before I intall.
The is the old one leaking, but a pic of the orfice tube you have to move from the old to the new.
Duct tape is over the gas line brass fitting for the inlet
If the 31150 is what you are looking for, here are 2 places I have bought from with positive outcomes.
https://pantherrvproducts.com/31150/?gcl........NCG9EVyOTf7f5OvMM7AB7R9DGBQaAgTUEALw_wcB
https://www.rvupgradestore.com/Atwood-31........LDHKaOknuwlIIxH2F8TdSitIP1saAq7OEALw_wcB
https://www.dyersonline.com/atwood-38604........nace-hydro-flame-side-out-gas-valve.html
Hope this helps
John
For the 31150, the gas outlet is in the wrong place. In your 2nd photo, the gas outlet is on the far side. On the 31155, the gas outlet would be to the right where your finger tips are, which is how mine is. Once mine is mounted in the furnace, the solenoids sit upright and the gas flows straight through from back to front. I suppose I might be able to rotate a 31150 and mount it sideways and use some fittings to get the gas line to the inlet port, which would face down, which is how it looks like yours is mounted. But I don’t have that L-shaped tube between the valve and the burner that is shown in your last photo.
Do you know if those caps with the allen head screws are removable? If so, could I swap the outlet from the side to the front?
* This post was edited 11/28/21 05:55pm by Bob E. *
Bob E.
Canonsburg, PA
Posted: 11/28/21 04:44pm Link  |  Quote  |  Print  |  Notify Moderator
BFL13 wrote:
Here are three photos of what goes in an 8531-II or III. It appears the gas valve is part of this assembly. 25M16V Type 701 is marked on it as shown.
">][image]
">][image]
">][image]
Yeah…that’s exactly what mine looks like. I’m actually rebuilding my camper from scratch so I have some freedom to adjust my gas line however I need it. I just need a valve that will bolt up to my furnace and allow it to run.
By the way, I’ve heard the actual burners are obsolete as well. I see you’ve gone through a couple. Where do you get replacements? I don’t need one now, but I might buy a couple to have on hand just in case.
BFL13
Victoria, BC
Posted: 11/28/21 04:55pm Link  |  Quote  |  Print  |  Notify Moderator
I think that 31150 would work. Just screw in your own inlet and outlet parts to the "back" and "front" holes (where those red things are?)
The burners are on Amazon. They now have a metal cover over the orifice then the screen starts. Works the same.
The sparker set they sell now has bent probes instead of straight like OEM. I was able to get separation above the screen by using washers as shims to tilt it up a bit. Hard to explain. I have a photo of that somewhere: OEM straight set seen there too. The straight ones were too far above the new burner screen and the new bent set was touching the screen, but is ok shimmed up as seen there.
">][image]
* This post was edited 11/28/21 05:14pm by BFL13 *
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
JBarca
Radnor, Ohio, USA
Posted: 11/28/21 09:47pm Link  |  Quote  |  Print  |  Notify Moderator
Hi Bob,
It seems there are different versions with the -II rev. I'll add some more pics of the 31150 so you can see if you can make it work. I looked in the 2003, 2007 and 2015 service manual and the -II rev 8500 series furnace called out a different valve part number in each manual. It seems they kept changing suppliers or valves etc along the way. I know the coils are slightly different on the wire connections on the new 31150 verses they old valve (2003 vintage) I replaced, but that did not stop the new valve from working.
The 31150 is made as a 90 degree valve. There is a pipe plug on the non outlet side opposite the actual outlet port, smaller NPT size but there is one. The 31150 had no outlet straight through from the inlet port like is seems you need.
I will have 2 of the 31150's arriving this week. I can take more pics or measure if that helps any.
See here for some more pics I have from earlier this year.
The inlet is on the right in this pic. See the molded in flow arrow.
The opposite side plugged outlet, smaller NPT port
There is no port on opposite end of the inlet port on the 31150
Here is the gas valve installed on the bench in 2010 in these 2 pics. These pics are of a 2003 vintage gas valve as that was when the camper was made the pics came from
Also to note, this pic is from 2010 as the date says and that valve is from a 8530-IV from 2003 which "looks" like it might have had a plugged discharge port straight out opposite the inlet. That feature went away with the current day 31150.
And this pic is of a 8520-IV and the valve is from 2003 installed. It too has what might be a port straight out, but again, That feature went away with the current day 31150.
Hope this helps
John
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
Bob E.
Canonsburg, PA
Posted: 11/29/21 10:51am Link  |  Quote  |  Print  |  Notify Moderator
Thanks guys! These photos and information have been very helpful. I ordered the newer gas valve (#31098) because it looks like it has the gas inlet and outlet ports in the correct place (or at least close to it). Supposed to be delivered Thursday. I'll let you know if it works when I get a chance to mess with it...hopefully this weekend. If not, I may have to go with the 31150 and try to find that L-shaped tube on the outlet side. Otherwise, I don't think I will have enough room at the bottom of the valve to connect the gas line on the inlet side.
 > Furnace gas valve
