RV.Net Open Roads Forum: Class A Motorhomes: Leveling Jack Creaking/Popping
 > Leveling Jack Creaking/Popping
Alex and Tee
Jacksonville , FL
Posted: 11/28/21 07:42am Link  |  Quote  |  Print  |  Notify Moderator
Having had our Open Road 36 LA for about 3 months now and aside from all the issues we have had with this unit so far, one of the most annoying things has been the creaking and popping noises from the leveling jacks while stationary.
It became rather annoying and having read on various forums others having this issue I purchased some silicone spray and fork oil. Being the skeptic I decided to try these fixes to this issue and also decided to take it one step at a time. Last week I took each jack while deployed and wiped down each shaft and sprayed each with silicone spray. I then retracted the jacks and redeployed them. A week later, not a creak or pop to be heard. The silence is beautiful.
I want to see how long this lasts before reapplying any spray or siphoning out a quart of hydraulic fluid and adding the fork oil. Hopefully this will be the cure and for once an easy fix.
Alex & Teresa
2022 Allegro Open Road
2021 Colorado 4x4
way2roll
Wilmington NC
Posted: 11/28/21 07:46am Link  |  Quote  |  Print  |  Notify Moderator
Probably more about your suspension relaxing/moving than the jacks.
stickdog
Somewhere, USA
Posted: 11/28/21 10:58am Link  |  Quote  |  Print  |  Notify Moderator
As you get older and your hearing worsens the only snap crackle and pop will be your joints. Fork oil and silicone won't stop that.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
“A good traveler has no fixed plans, and is not intent on arriving.” Lao Tzu
olfarmer
Iowa
Posted: 11/28/21 02:07pm Link  |  Quote  |  Print  |  Notify Moderator
What kind of jacks do you have? I have had good luck with silicone spray on my HWH jacks. I have never heard of fork oil, what is that?
Ed & Ruby & the 2 cats
2001 Winnebago Brave 30W
7.4 gas Work Horse Chassis
99 Jeep Grand Cherokee
Alex and Tee
Jacksonville , FL
Posted: 11/28/21 04:03pm Link  |  Quote  |  Print  |  Notify Moderator
Tiffin stopped using that brand this year and now use Lippert jacks. Fork oil is used in motorcycle forks and is recommended by Lippert as an additive to the hydraulic oil.
LadyRVer
Posted: 11/28/21 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
When my Class A did that, the dealer told me to put a little more weight on the jack which was doing the popping/creaking. It worked for me.
olfarmer
Iowa
Posted: 11/28/21 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
OK on what the fork oil is, thanks.
dougrainer
Carrolton, Texas
Posted: 11/29/21 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
I believe Tiffin still uses HWH. They dropped HWH on just the Open Road models. And yes, the Additive will stop the problem. They used to call the additive anti/Sticksion additive. This is LCI's fix for the problem on their jacks.
