RV.Net Open Roads Forum: Fifth-Wheels: Puck system & hitch questions
 > Puck system & hitch questions
riltri
Husk & Steinhatchee
Posted: 11/28/21 10:05am Link  |  Quote  |  Print  |  Notify Moderator
I'm moving from a LB GM to a Ford with 6.75' bed. The truck does not have factory installed puck system. I want to stick with a new B&W slider hitch (I don't think that a slider is required with my 2015 5th wheel's rounded nose, but want the option of using it). Will be pulling 12,300lbs.
- Which puck system should I have the dealer install?
- Can the Patriot slider easily handle 12.2k lbs? I know it is rated for 18k but has anyone heard of issues with it?
Thanks
Blue Ridge Mtns - NC
MFL
Midwest
Posted: 11/28/21 10:17am Link  |  Quote  |  Print  |  Notify Moderator
The Ford OEM puck system is available from Ford Accessories, and the Patriot is a great hitch, can easily handle your Fw wt. Mine is not a slider, but very well built, very easy to use, and no worries (is it hitched, or not).
Jerry
MFL
Midwest
Posted: 11/28/21 11:26am Link  |  Quote  |  Print  |  Notify Moderator
I think you will need the B&W Companion slider, for a direct fit to Ford OEM underbed puck system. ICBW, haven't followed updates. [emoticon]
Jerry
Durb
NW
Posted: 11/28/21 11:34am Link  |  Quote  |  Print  |  Notify Moderator
The Patriot fits on industry standard rails, not on factory puck systems.
riltri
Husk & Steinhatchee
Posted: 11/28/21 11:36am Link  |  Quote  |  Print  |  Notify Moderator
Jerry
I think you are correct. The dealer did spec the B&W Patriot but did not mention which underbed system they are installing. Will be making a phone call first thing in the morning....good thing the installer is backed up 2 weeks!!!
riltri
Husk & Steinhatchee
Posted: 11/28/21 11:37am Link  |  Quote  |  Print  |  Notify Moderator
Are the rails fixed in place or can they be removed along with the hitch?
* This post was edited 11/28/21 11:45am by riltri *
buc1980
houston tx
Posted: 11/28/21 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks
Do you know you can install the pucks yourself just buy the parts.That what I did.
2017 Ford F350 DRW,2005 Kountry Star 35ft,16750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.Full body paint 2022.
Cummins12V98
on the road
Posted: 11/28/21 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
Buy Puck parts install your self. Buy a new Patriot slider. Sell old Patriot on CL
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
riltri
Husk & Steinhatchee
Posted: 11/28/21 02:34pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks to everyone for all the input. VERY helpful!!
It's my understanding that the Patriot will not fit the puck system. It only fits the rails which I do NOT want. We only pull 4 days each year. The hitch is out of the truck the remainder of the time. Don't want those rails attached to the bed.
My current thought is to cancel the 5th wheel prep and hitch. Then buy the puck system...intall it myself...purchase a Companion slider base (fits puck system)...use the head from my current fixed Companion hitch.
Purchased truck the day before Thanksgiving. Hope to cancel the 5th package in the morning....we will see!
MNRon
Tennessee
Posted: 11/28/21 04:48pm Link  |  Quote  |  Print  |  Notify Moderator
Why would you cancel the 5er package on a new truck? I believe it comes with in-bed 7pin and some other things. I also ordered an F350 within the last month and can’t imagine not getting the 5er package.
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
