RV.Net Open Roads Forum: General RVing Issues: suggestions for a better shower head????
 > suggestions for a better shower head????
centerline
Salem OR
Posted: 11/28/21 01:02pm Link  |  Quote  |  Print  |  Notify Moderator
im looking for suggestions for a shower head that will give a wider spray of water.
the one that i have now sprays about a 2inch pattern at 24inches from the shower head, and I would prefer to have one that has about a 5inch spray pattern....
due to heartlands use of the plastic fittings in the 1/2" pex line, which only have a 5/16 pathway thru them, more water flow and pressure is not an option without replacing all the joints with metal fittings, or upgrading to a larger size line thruout the freshwater plumbing system....
those of you who have a good spray pattern from your shower head, what brand or type are you using?.... thanks
2007 M-3705 SLC weekend warrior, 5th wheel
2014 Ram 3500 CC/LB, 6.7 Cummins
2004 Polaris Sportsman 700
2005 Polaris Sportsman 500 HO
1979 Bayliner 2556 FB Convertible Cruiser
Heavy Equipment Repair & Specialty Welding...
agesilaus
North Florida
Posted: 11/28/21 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
The Oxygenics is probably the most popular: Oxygenics Shower Head
They work on low flow making your limited hot water supply last longer. There are several different versions not just the above. We have had one for years.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
Michelle.S
Western NY till fall, then Sebring, FL
Posted: 11/28/21 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
Ditto the Oxygenics Shower head.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
#1Flyboy
California
Posted: 11/28/21 06:45pm Link  |  Quote  |  Print  |  Notify Moderator
X10
JimK-NY
NY
Posted: 11/29/21 06:08am Link  |  Quote  |  Print  |  Notify Moderator
The Oxygenics works great if you want a fairly powerful spray. It is horrible for conserving water if you do not have hook ups. Check their webpage. The Oxygenics heads are designed to use a full gallon of water per minute and they do not work at all well if you need to conserve water.
agesilaus
North Florida
Posted: 11/29/21 08:11am Link  |  Quote  |  Print  |  Notify Moderator
That is why 'Navy' showers are recommended for water conservation. Run the water get wet, shut the water off, soap up. run the water to rinse. Does not matter what shower head you use. And just for your info, in the Navy we went weeks or months without even a "Navy" shower on submarines.
Cummins12V98
on the road
Posted: 11/29/21 09:07am Link  |  Quote  |  Print  |  Notify Moderator
I have the Oxygenics with an added shut off valve where the hose connects to the head. By using the valve I can fully shut off the water and it's the same temp when opened. With the lever on the head only shutting it iff there is still some flow and when re opened you have to wait for the temp to even out.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
dedmiston
The West
Posted: 11/29/21 10:22am Link  |  Quote  |  Print  |  Notify Moderator
This weekend I was thinking to myself, why is it that the residential shower at home always feels "pretty good" but showering in the RV feels so amazing? It was especially dusty and grubby at camp this weekend, so I showered every night before bed. I don't know why this feels like such a luxury.
Toys:
  • 18 Can Am Maverick x3
  • 05 Yamaha WR450
  • 07 Honda CRF250X
  • 05 Honda CRF230
  • 06 Honda CRF230
Sandia Man
Rio Rancho, NM
Posted: 11/29/21 12:11pm Link  |  Quote  |  Print  |  Notify Moderator
A gallon a minute is pretty good IMO for a showerhead, no wonder our Oxygenics has proven a water saver for us. We shower daily without exception, twice if we are swimming in river, lake, or ocean, great to know we are using just a couple of gallons if even that much since it is rare we run showerhead more than 2 minutes total. We have been RVing for 3 decades and boondocking is easily our favorite method, all the stock showerheads in the various rigs were changed out for Oxygenics versions, we noticed a significant reduction in FW usage compared to stock, a more invigorating stream was an added bonus.
JimK-NY
NY
Posted: 11/30/21 07:15am Link  |  Quote  |  Print  |  Notify Moderator
Sandia Man wrote:
A gallon a minute is pretty good IMO for a showerhead.....
Not for me. I regularly stay in places without hookups and often where water is scarce. I use 1 gallon of water or less for my daily shower. I wet down with a dribble of water, soap up and rinse again with a dribble of water. I have also solved the waste issue adjusting the temperature. I only use the water heater for showers and know how long to run the heater to get the water to a comfortable temp. My only waste is about a cup of water getting the hot water from the tank to the shower head.
