RV.Net Open Roads Forum: Tech Issues: Vacuum issues
 > Vacuum issues
cannesdo
Presently in Encinitas, CA
Posted: 11/28/21 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
My rig is 20 years old. The house vacuum suction pretty much stopped. I've run a snake through the tube and don't feel any blockages. it smells hot even when I disconnect the hose from the box in the basement and pull up the tab so it powers on. Do you suppose the whole vacuum is fried? Even if the there was a blockage, with the hose disconnected the vacuum shouldn't smell hot.
Thanks...
lryrob9301
Mid-Atlantic
Posted: 11/28/21 02:33pm Link  |  Quote  |  Print  |  Notify Moderator
When's the last time the bag was changed?
2013 Tiffin Phaeton 40QBH
2016 Chevrolet Equinox LTZ AWD V6
jkwilson
Indiana
Look inside. Dust can clog the screen to the motor.
John & Kathy
2014 Grand Design Reflection 303RLS
2014 F250 SBCC 6.2L 3.73
Posted: 11/28/21 03:35pm Link  |  Quote  |  Print  |  Notify Moderator
I agree pull the hose at the motor and see if you have suction there. if not it's internal to the "Box" (inlet screen) And the comment about the bag... Now I do not think central vacs in RV's have those (I think they just blow it to the ground) but.... THINK means it's possible I'm mistaken.
At 20 years might be a toasted motor too.
cannesdo
Posted: 11/28/21 04:57pm Link  |  Quote  |  Print  |  Notify Moderator
Ok...I'll check the screen leading to the motor. I've changed the bag regularly.
cannesdo
Posted: 11/28/21 04:58pm Link  |  Quote  |  Print  |  Notify Moderator
 > Vacuum issues
