RV.Net Open Roads Forum: Travel Trailers: Best exterior tape
 > Best exterior tape
Skinny D
California
Posted: 11/29/21 12:09pm Link  |  Quote  |  Print  |  Notify Moderator
What is the best tape (or other method) to secure wires to the underside of the TT?
I installed lithium ion batteries and an inverter in the front pass-thru storage compartment. Thus, I had to run wires from the compartment under the refrigerator (fuse and breaker panels), out the bottom of the TT, up to the front along the underside, then up through another hole into the compartment. The bottom is some kind of polymer or plastic sheet material. There is nothing to twist tie to.
I used Gorilla Glue tape which was supposed to be a permanent bond but most of that has fallen off and I have repeatedly applied more.
2oldman
Nevada
Posted: 11/29/21 12:29pm Link  |  Quote  |  Print  |  Notify Moderator
I've used Dicor to hold solar wiring. Of course it takes awhile to set so you'd have to support those wires somehow. Come to think of it, how about Eternabond tape? That stuff should hold anything.
JBarca
Radnor, Ohio, USA
Posted: 11/29/21 12:50pm Link  |  Quote  |  Print  |  Notify Moderator
This sort of depends how the bottom of your camper is made.
Is the bottom of your camper wide open up to the black plastic waterproof membrane? Or is there a Coroplast plastic cover on the bottom and an enclosed tank compartment etc?
This solution works well on campers that you can feel the floor joists just above the black plastic waterproof membrane. And assuming the floor joist is wood, if you have aluminum joists, they can work too.
Use one hole nylon cable clamps with an screw into the floor joist. These kind of clamps in the size you need. Add them as needed to the joists to not have the wire droop. There are many brands of them.
https://www.homedepot.com/p/Gardner-Bend........EC-_-pipsem-_-100167050-_-100158293-_-N&
If you have the Coroplast cover, well drop the cover and still go up to the joist.
Gorilla tape is good stuff, but this may not be the best place to use it assuming you want lots of years worth of service.
Also, the above makes the assumption this is low voltage DC wiring. If you are running 120VAC wiring, this is ideally in plastic conduit or other protective cover when exposed to the road splash, abuse from anything hitting the wire, etc.
Hope this helps
John
John & Cindy
2005 Ford F350 Super Duty, 4x4; 6.8L V10 with 4.10
CC, SB, Lariat & FX4 package
21,000 GCWR, 11,000 GVWR
Ford Tow Command
1,700# Reese HP hitch & HP Dual Cam
2 1/2" Towbeast Receiver
2004 Sunline Solaris T310SR
(I wish we were camping!)
Anza-Borrego Desert SP area
Posted: 11/29/21 01:21pm Link  |  Quote  |  Print  |  Notify Moderator
12 volt....Eternabond.
120 volt....plastic conduit
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
Beaker
Brevard, NC
Posted: 11/29/21 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
That is what I used. Used the handle of the sissors with good
pressure to rub the tape. Pay close attention to the edge of the tape when rubbing.
2008 Silverado 2500HD Duramax
2010 Cruiser 26RK
NamMedevac 70
Reno
Posted: 11/29/21 10:27pm Link  |  Quote  |  Print  |  Notify Moderator
Yes I have very good results with white Eternal Bond tape that last a very long time exposed to the road and weather elements near bottom of my TT. I know from experience that Gorilla tape will dry out and flake off/away in due time even indoors.
* This post was edited 11/30/21 07:25am by NamMedevac 70 *
markandkim
Swansea, MA.
Posted: 11/30/21 04:57am Link  |  Quote  |  Print  |  Notify Moderator
Underside, black Gorilla tape.
Retired Navy
2020 Ram 2500 Bighorn 6.7L
2014 Crossroads Zinger 27RL
CavemanCharlie
Storden,MN
Posted: 12/01/21 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
Actually, there is no reason you couldn't use plastic conduit for the 12 volt wires. If you could support the conduit in a couple of places it would do the trick. Depending on how far your run is maybe you could just support it on both ends ?
mobeewan
Hampton, Va
Posted: 12/03/21 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
Plastic wire harness clips
Plastic wire loom &
Plastic wire loom clips
Plastic wire p clamps/clips
Rubber insulated metal clamps
Plastic wireways
Eternabond
Small PVC or plastic tubing
rhagfo
Portland, OR
Posted: 12/04/21 05:54am Link  |  Quote  |  Print  |  Notify Moderator
Why not snake them through the underbelly of the trailer, above the coreplast.
