RV.Net Open Roads Forum: Fifth-Wheels: Fifth Wheel Hitch What Kind
 > Fifth Wheel Hitch What Kind
Page of 5
mike24
Pennsylvania
Posted: 11/30/21 11:13am Link  |  Quote  |  Print  |  Notify Moderator
A friend of mind has a B & W hitch, so I asked him what are the cons, and the first thing he said which I saw on video when you release the handle it is hard to reach without a step, the other thing is, always removing the head to grease the plastic bushings that the head sits on because the grease squeezes out, also E-trailer saying the hitch weighs 220 LBS. I have a Ram 8FT bed puck system, I am wondering how people feel about the Curt A series and the Q series hitch, what's the difference and which is better, I have a Moryde pin box and the hitch can have a max. rating at 20,000 LBS. It is good to read opinions from the end user. Thanks for your help.
ACZL
UPstate,NY
Posted: 11/30/21 11:19am Link  |  Quote  |  Print  |  Notify Moderator
This ought to be fun
2017 F350 DRW XLT, CC, 4x4, 6.7
2018 Big Country 3560 SS
"The best part of RVing and Snowmobiling is spending time with family and friends"
"Catin' in the Winter"
cummins2014
Utah
Posted: 11/30/21 11:55am Link  |  Quote  |  Print  |  Notify Moderator
I agree, the B&W fan club should be along soon.
To the OP ,look into Andersen hitch .
* This post was edited 12/01/21 07:43am by an administrator/moderator *
MFL
Midwest
Posted: 11/30/21 12:38pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, if you are short (less than 6'3"s) you will need reach enhancement. That B&W for Ram pucks has a heavy base for sure. The grease on the bushings, only needs to be a light layer. If oozing out, you're using too much, maybe wrong grease?
No experience with the Curt, but it would likely be lighter.
Jerry (B&W fan club member)
ReneeG
Meridian, Idaho
Posted: 11/30/21 01:30pm Link  |  Quote  |  Print  |  Notify Moderator
[emoticon]
He didn't mention spending limit so I say check into a Hensley TrailerSaver BD3 or BD5.
* This post was edited 12/01/21 07:44am by an administrator/moderator *
2011 Bighorn 3055RL
2011 F350 DRW 6.7L 4x4 Diesel Lariat and Hensley BD3
1992 Jeep ZJ and 1978 Coleman Concord Pop-Up for remote camping
Dave & Renee plus (Champ, Molly, Paris, Missy, and Maggie in spirit), Mica and Mabel, both Rat Terriers!
MFL
Midwest
Posted: 11/30/21 01:42pm Link  |  Quote  |  Print  |  Notify Moderator
Good one! I agree, especially if chucking is a concern. [emoticon]
way2roll
Wilmington NC
Posted: 11/30/21 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
I wanted a B&W when we bought our FW due to the positive feedback I read and heard personally. There wasn't one available at the time we bought and I didn't want to wait so we went with an Curt A. I have to say I am very happy with it. It's not terribly heavy and the head easily comes off so you can remove it in 2 pieces which is easily manageable by yourself. It's easy to lube the jaws and no other lube is necessary with a plate. I think any hitch release lever, regardless of brand is going to have a reach challenge. More to do with the height of the truck than the latch. Don't stand on the tire to release! The truck might rock an inch and cause you to fall off - ask me how I know. I still have to hop in the bed to hook/unhook the breakaway cable but again, more to do with where the cable is and the height of the truck than the hitch. the Curt latches and unlatches cleanly and easily and a few times I wasn't completely square or level. The only negative thus far is that it's a little noisy. Small amount of play where the legs connect to the rails allows it to rattle and clunk on road separations. Maybe this wouldn't be an issue with a puck system, but I just insert some polymer shims and that solved the issue. I'm a little OCD about noises, it doesn't affect functionality at all. After a year of regular use I am very happy with it.
I don't know anything about the Q model.
on edit I did find this on Etrailer:
The A series of Curt 5th wheel trailer hitches, such as # C16120, is the newest version and is replacing the Q series. The A series jaws overlap whereas the Q series butt up against each other more than overlap. And the bearing and shaft that the head pivots on is different between the 2. They do look very similar, in fact the specs and design are identical like you said, but you can think of the A series as the new and improved version of the Q series.
* This post was edited 11/30/21 02:09pm by way2roll *
Hammerboy
Zeeland, MI
Posted: 11/30/21 08:37pm Link  |  Quote  |  Print  |  Notify Moderator
There is a reason there is such a huge fan base, dang good hitch.
Dan
2019 Chevy crew LTZ 2500 HD Duramax
2017 Wildcat 29rlx fifth wheel
ACZL
UPstate,NY
Posted: 12/01/21 02:18am Link  |  Quote  |  Print  |  Notify Moderator
Personally,
I too am a member of the B&W club and have to use a tire step to reach the hitch only cuz the truck is too dang tall and I'm too dang short! No chucking at all and just add a layer of white lithium grease on rubber bushing 1-2x/yr and that's it (besides greasing the zerk). Yes base is heavy and head is a little lighter, but it's made in the USA, multitude of adjustments. 18k Patriot.
ford truck guy
Pennsylvania
Posted: 12/01/21 06:02am Link  |  Quote  |  Print  |  Notify Moderator
Another B&W Fan Club Member here......
I was a bit skeptical at first because of the stellar treatment I received while owning my Pullrite Superglide. 2 years in and I am impressed [emoticon]
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Page of 5
