RV.Net Open Roads Forum: Travel Trailers: Half ton towing
 > Half ton towing
Page of 7
GrandpaKip
Flat Rock
Posted: 12/03/21 08:04am Link  |  Quote  |  Print  |  Notify Moderator
Gosh golly gee Batman, there must be thousands and thousands of overloaded Silverado’s, F150s, Ram 1500s and Tundras pulling trailers out there.
Ohhh, the humanity!
Kip
2015 Skyline Dart 214RB
2018 Silverado Double Cab 4x4
Andersen Hitch
Timmo!
Far away from this WOKE website!!!!!!!!!!!!!!!!!!!
Posted: 12/03/21 08:12am Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
@Timmo, maybe good time to stop proving your theories with mfg data unless you understand it. There's NO 2000lb payload increase on a F250 due to lower gears. Here's where reading comprehension and understanding vehicle classifications comes in. That chart is for 250/350 srw trucks and the 2000lbs more is a F350 vs a F250....
You a funny guy! So you are saying Ford did not manufacture a 2005 F250, 5.7L with 4.10 that has a GCWR of 18k lbs? You are entitled to your fantasy. But facts are facts....
01tundra
Middle, TN
Posted: 12/03/21 08:39am Link  |  Quote  |  Print  |  Notify Moderator
Ohhh, the humanity!
I think it really depends on your definition of "overloaded".
If your definition of overloaded is travelling above the manufacturer's specified GVWR of the vehicle, then yes, I'd say there are thousands of people pulling overloaded, and that also includes many 3/4-ton vehicles, based on data I've seen from people who even bother weighing their rigs.
On the other hand, if your definition of overloaded is pulling over the rated "tow capacity"....then most are likely within that magical number.....
Then there's overloaded as in over the rear axle GAWR.
* This post was last edited 12/04/21 12:59pm by 01tundra *   View edit history
2020 Rockwood Mini Lite 2109S
2017 GMC 2500HD Denali Duramax
Posted: 12/03/21 11:29am Link  |  Quote  |  Print  |  Notify Moderator
Nope, I'm not saying that at all, in fact, presuming the chart you posted is correct, you are also correct that a 250 with deeper gears has or should have a correspondingly greater gcwr.
But you said "but for the F250 there is a 2000 lb increase in both cargo cap AND towing cap"
The F250 does NOT have a 2000lb increase in cargo cap, aka payload rating. That chart encompasses 2 different models of trucks that have or can have significantly different gvwrs.
It can't unless the mfg drops a literal ton off the bare weight along with the gearing change, as payload ratings for 3/4 tons are based off of the, relatively low/limited gvwr - curb weight.
And while the deeper gear ratio upping the GCVWR "could" theoretically increase payload rating, it doesn't as the limiting factor for payload isn't the engine and gearing. It could have a 180hp inline 6 and still adequately carry most any payload. The gcvwr is largely related to towing capacity.
PS, it's a 5.4L, but I know that's just a typo.
2017 Heartland Torque T29
Posted: 12/03/21 11:31am Link  |  Quote  |  Print  |  Notify Moderator
Ohhh, the humanity!
That's what gets the internet experts and weight cops all twitterpated, yup, 10-4, correctomundo. Makes for fun debates!
shelbyfv
TN
Posted: 12/08/21 11:13am Link  |  Quote  |  Print  |  Notify Moderator
My F150 has a payload of only 1500lbs. It's a lightly optioned XLT. The fancier versions may have even less. Add a fiberglass cap and I'd definitely be over with a 1000lb tongue weight. 1/2 ton owners need to check the sticker and make an honest assessment of the other cargo. May be surprising how little tongue weight you can add. The towing limits might have you thinking big trailer but the payload will bring you back to earth.
ferndaleflyer
everywhere
Posted: 12/08/21 11:47am Link  |  Quote  |  Print  |  Notify Moderator
I am not a weight nut. Last week I towed about 5000lb trailer with my F-150 and it towed better than anything I have towed in years. Real eye opener as I have always said "you never have to much truck".
Mike134
Elgin, IL
Posted: 12/08/21 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
Ohhh, the humanity!
It really becomes like a 6 beer debate at the saloon, only difference folks sitting at a PC chucking beers offering their humble opinions.
Safe travels.
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
mooky stinks
Cicero,NY
Posted: 12/08/21 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
I like it when people ask about towing with my f150 at the campground. Sometimes it goes long enough that I mention the HDPP and they look at me like I have 2 heads. They have no idea what it is or that it’s available. I’m sure some of them walk away thinking I’m making it up.
2020 F150 XL Screw 4x4 6.5”box
3.5 ecoboost Max tow HDPP
7850 GVW. 4800 RAWR
2565 payload
2020 Cougar 29RKS 5th wheel
Bobbo
Wherever I park
Posted: 12/08/21 08:49pm Link  |  Quote  |  Print  |  Notify Moderator
When I was about to buy my new TT and truck, I did the math and calculated I was comfortable towing up to a 6,000# GVWR trailer with an F-150 that is properly optioned to maximize the payload rating. (My payload rating is 1,895#.)
Bobbo and Lin
Page of 7
 > Half ton towing
