RV.Net Open Roads Forum: Travel Trailers: Half ton towing
 > Half ton towing
Page of 7
valhalla360
No paticular place.
Posted: 01/04/22 09:57pm Link  |  Quote  |  Print  |  Notify Moderator
Grit dog wrote:
@ Gdetrailer
"Towing ratings now days has very little to do with gear ratios for the most part."
Except that in Timmo!'s example, it is largely gear ratios and engine power that make the tow ratings near the same. It aint the chassis.
With the modern 8/10speed transmissions, gear ratios are far less important unless you are trying to push the upper limits of tow ratings...then it's usually better to jump from 1/2ton to 3/4ton anyway (or alternatively to a more powerful engine option).
In the old days (I think there was mention of a 2005), with a limited number of gears, a truck with a low numerical rear end ratio was more efficient when running empty but as soon as you hooked up a trailer, it often would be forced down a gear even on flat ground and since it was a big jump in gear ratio, it often left the engine RPM racing far higher than ideal. So if you were going to tow a lot of the time, a higher numerical rear end ratio would allow you to hold top gear and keep the RPM more reasonable while towing.
With 8/10 speeds, the change in gear ratio by dropping a gear is much smaller, so the truck can dial in much closer to the ideal RPM/HP range that is ideal for the engine.
Tammy & Mike
Ford F250 V10
2021 Gray Wolf
Gemini Catamaran 34'
Atlee
Mechanicsville, VA
Posted: 01/17/22 02:57am Link  |  Quote  |  Print  |  Notify Moderator
Experienced towers know the importance of the cargo capacity, but most "newbies" do not. There is very little education for them.
Unfortunately, most, if not all, YouTube reviewers, let alone the manufacturers, will tout the amazing number of pounds the truck is rated to pull, yet they never mention the cargo capacity which is the most important number since it's so easy to exceed.
I wish all the reviewers would talk about the cargo number during their "reviews".
Erroll, Mary
2021 Coachmen Freedom Express 20SE
2014 F150 Supercab 4x4 w/ 8' box, Ecoboost & HD Pkg
Equal-i-zer Hitch
Page of 7
 > Half ton towing
