RV.Net Open Roads Forum: Trouble finding alcohol free RV antifreeze this season?
 > Trouble finding alcohol free RV antifreeze this season?
StarkNaked
West Seattle, WA
Posted: 11/30/21 05:05pm Link  |  Print  |  Notify Moderator
Is everybody having trouble finding alcohol free RV antifreeze this season?
Walmart has always had it in past seasons. This year, three different brands, but all alcohol based.
Checked on line, Home Depot had it at a store 15 miles away (plus at other stores even further). Drive all the way there, but they can't find it. Now when I check again on line, they have zeroed out all inventory within 100 miles of my zip code.
Drive to the local hardware chain (since they don't do on line inventory) and they have several brands as well, but all alcohol based.
Try Autozone, same thing. Two different brands, but all alcohol based.
Is everybody having this problem?
rk911
DuPage County
Posted: 11/30/21 07:44pm Link  |  Print  |  Notify Moderator
i thought the 'pink stuff' was vegetable based. ???
Rich
Ham Radio, Sport Pilot, Retired 9-1-1 Call Center Administrator
2016 Itasca Suncruiser 38Q
'46 Willys CJ2A
'03 Jeep Wrangler TJ
'10 Jeep Liberty KK
& MaggieThe Wonder Beagle
Bobbo
Wherever I park
Posted: 11/30/21 07:55pm Link  |  Print  |  Notify Moderator
Ummm, why do you want it to be alcohol free? Not trying to start something, I really want to know the rationale.
All you are trying to do is get the water out of the system. The pink stuff with alcohol will do that. Once the water is out, you can safely drain the pink stuff out too. It doesn't have to remain in the system. The water is gone.
The RV antifreeze is either ethanol based or propylene glycol based. (Note that there is NO ethylene glycol in it. That is in car antifreeze and is deadly.) I am assuming that the OP is talking about avoiding the ethanol based stuff. However, technically, propylene glycol, also, is an alcohol.
Bobbo and Lin
rk911
DuPage County
Posted: 11/30/21 08:02pm Link  |  Print  |  Notify Moderator
ok...we need clarificafiom. OP....are you looking for engine anti-freeze or anti-freeze for the RV's fresh water system? pretty sure the latter is vegetable based.
fj12ryder
Platte City, MO
Posted: 11/30/21 08:30pm Link  |  Print  |  Notify Moderator
I never checked to see which I get, they have all worked like they should so I don't really care. Been doing it for 10 years with no issues, so it all seems to work okay.
Howard and Peggy
"Don't Panic"
KD4UPL
Swoope, VA
Posted: 11/30/21 08:33pm Link  |  Print  |  Notify Moderator
I ordered in a couple gallons of alcohol free Propylene glycol when I winterized my boat. I didn't have any trouble finding it online. I got it from an online marine retailer. I think it was West Marine. I didn't even try the stores. Our nearest Home Depot is about 30 miles away but then it's 15 miles to the nearest traffic light.
What's with all the "vegetable based" comments? I've never heard of such a thing. It's propylene glycol.
StarkNaked
West Seattle, WA
Posted: 11/30/21 08:49pm Link  |  Print  |  Notify Moderator
The alcohol-based stuff has two things I would like to avoid. First is it is flammable. Second is that alcohol is harder on rubber seals (like in the dump valves).
And for others that have asked, I'm talking about winterizing the fresh water system.
And thanks for the West Marine suggestion. I have a couple boat places I can try.
StarkNaked
West Seattle, WA
Posted: 11/30/21 09:03pm Link  |  Print  |  Notify Moderator
Thanks to KD4UPL.
Yes, West Marine has it in stock. West Marine
My local store has over 1000 gallons sitting on the shelf!
They have 5 different blends, all but one are alcohol free.
Dave H M
IL
Posted: 12/01/21 01:36am Link  |  Print  |  Notify Moderator
I saw this flammable legend a few years back. Hmmmmm, so being curious I poured some on the pad in front of the barn and took to it with a portable propane torch. Could not get it to light. [emoticon]
Posted: 12/01/21 04:59am Link  |  Print  |  Notify Moderator
What is your objection to alcohol based other than alcohol in a non pressurized system can evaporate and leave you unprotected (Takes time however)
Suggestion The Best RV antifreeze I've ever used is air. Yup Air. I hooked up the old huffer puffer (Actually I sould not say that as that's an actual brand and I used a Crafstman) set the regulator to about 50 PSI and used a blow out adapter. Opened every valve and blew out the lines.. Then cycled the Ice maker manually to drain that line, Flushed toilets to drain those lines and blew again, and blew again.. Eventually I was getting no more water (About 10 blows) and then I put pink stuff in the drains and toilets I had an at-home sewer connection so I dumped and then added a bit more pink to protect the dump vlves With two toilets. 3 laves and a sink I used about 2 gallons of pink.
Next spring... Instead of having to get all that nasty pink out of the fresh water system..... Well let's just say that was NOT a problem... and as for the pink in the drains. not a problem either.
