Michelle.S
Western NY till fall, then Sebring, FL
I was hoping to get 5 years out of my GY G114s, but one blew at 4 1/2 year, lucky it only took the Plastic Fender Skirt.
Now have 2 year old 17.5 .Sailuns and already lost a section of tread on one and it's made in China and before the recall date. So maybe the change was made in China before Vietnam.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
JIMNLIN
Oklahoma
ChuckSteed wrote: YES - NINE YEARS of use wasn't the brightest thing with a set of RV tires.. 5 maybe depending on how they are cared for and weight load and speeds towed at..
But to run a set of RV tires nine years you were lucky you didn't have issue your really didn't want
The Michelin XPS Ribs is a commercial grade all steel ply carcass LT tire that Michelin recommends for commercial trailer service. The LT XPS Ribs work great on trailers with 6k and smaller axles and are much preferred over the usual poly carcass ST tire.
Michelin replacement policy says;
**it is recommended that any tires in service 10 years or more from the date of manufacture, including spare tires, be replaced with new tires as a simple precaution even if such tires appear serviceable and even if they have not reached the legal wear limit.
and from a Michelin XPS Ribs add says;
**Michelin® XPS Rib® tires are the best value per mile in the Michelin commercial tire lineup and an ideal choice for commercial trailers because of low rolling resistance (for better fuel economy), a long-wear tread design and retreadability. These tires also have the strength of a reinforced all-steel construction for lasting durability.
Responsive handling helps you negotiate through tough traffic
Greater durability and puncture
resistance from a third steel belt.
Easily retreadable all-steel casing
Lowest cost per mile in this category
Resists sidewall damage with the sculptured sidewall protector.
Sidewall: black serrated
outline lettering.
Load Range: E
Service Description: 120/116Q
Me Again
Sunbird(Wa)/snowbird(Az)
I ran a set of RIBs on 5200 axles for 6.5 years and sold them with 65% tread left for 200 bucks on CL and then ran R250 for 4.5 years until I sold that trailer.
2021 F150 2.7 Ecoboost - Summer Home 2017 Bighorn 3575el. Can Am Spyder RT-L Chrome, Kawasaki KRX1000. Retired and enjoying it! RIP DW 07-05-2021
Retired JSO
North Georgia Mountains
I was concerned because I had put on a set of Sailuns this past spring. The Cardinal was in the barn with the slides out so it made it difficult to see much. Yesterday, I read the date code 3320, thinking oh **** but then I saw Made in China so I’m good.
joebedford
Made It!
momentum rv wrote: Copied from another thread...
Sailun Tire Americas, Inc. (Sailun) is recalling certain Sailun, RoadX, Blacklion, Blackhawk, and Ironhead brand tires, sizes ST235/80R16 and ST235/85R16 with DOT codes 2020 through 4120. Due to a manufacturing issue, the tires may experience a belt separation. Belt separation could lead to loss of vehicle control, increasing the risk of a crash. Sailun will replace the tires, free of charge. Owner notification letters are expected to be mailed in December 2021. Owners may contact Sailun customer service at 1-844-281-9696. Is this a quote from a letter from Sailun or a thread somewhere?
My 6 tires are dated 4319 / Made in China but Walmart where I bought them sent me an email saying
"Our records reflect that you may have purchased one or more of the below items:
UPC
0695965540992 SAILUN S637 TRAILER TIRES
0695965541960 SAILUN S637 TRAILER TIRES"
Date code is easy to find but where can I find the UPC?
WE-C-USA
NW Missouri
Joe I got the same message today and wondered the same thing.
Frank & PJ
2022 2500HD GMC Duramax 4X4
2018 Grand Design-Refection 303RLS
momentum rv
Central Cal.
On one side of my tires there is a semi-embedded white label with a number and barcode.
2015 Grand Design Momentum 385TH
2015 Ford F-350 DRW 4x4 Lariat
joebedford
Made It!
Do you mean the white tag at the top of the photo? It doesn't conform to either of the UPC Walmart sent.
![[image]](https://i.imgur.com/onnVnROl.jpg )
Click For Full-Size Image.
last
edited 12/27/21 09:22am by joebedford *
View edit history
momentum rv
Central Cal.
joebedford wrote: Do you mean the white tag at the top of the photo? It doesn't conform to either of the UPS Walmart sent.
Yes. So I don't know what else it could be.
BarneyS
S.E. Lower Michigan
Your photo never appeared at all. It may have appeared on your computer but it never showed on mine or, I suspect, anybody else's.
To post a picture on the forums, go to this site, upload your picture to the app, copy the resulting URL and paste into your post without adding anything at all to the URL. No additions and no subtractions. Simply copy and paste it into a post.
Your picture will then appear and be properly sized for use on our forums.
Good luck.
Barney
edited 12/27/21 06:17am by BarneyS *
Not towing now.
