Lantley
Ellicott City, Maryland
Cummins12V98 wrote: If the Sailun tires still look good I would not hesitate going 8 years.
My last set went 8 years. I'm on my 2nd set. 2nd set is 2 camping seasons old.
Interestingly I had a axle/bearing issue complete with wheel fire that overheated the hub and caused a blowout.
Luckily I had zero body damage to the 5'er. The Sailun popped but did not disintegrate.
I chained up the axle manage to limp the rig back home 30 miles or so on 3 tires.
I did replace both the blowout tire and the tire beside it that carried the additional weight as we limped back home.
I would not switch tires brands due to any percieved or real problems with a batch of Sailun tires.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
buc1980
houston tx
RetiredRealtorRick wrote: Doesn't Michelin make trailer tires? The RIB are not trailer tire.I use to have them but they blow and at that time I replace the with Sailun(I said at that time)Goodyear 614 was a very bad tire back in 2005-2008.I don't want to buy the bad batch(Sailun) so I look somewhere else.
2017 Ford F350 DRW,2005 Kountry Star 35ft,16750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.Full body paint 2022.
walker111
se calgary
I am also on my second set of saliuns on my voltage TH. Got 6 years and about 35000 k on the last set. I did notice the Vietnam print on the sidewall. I hope they work out like the last set. I don't tow as much anymore as my boys are now 15 and 18 and do their own things more and more.
Of note, I found Bridgestone Blizzacks in the LT for winter tires for my truck and was amazed that they were made here in good ole CANADA!!!!
Cummins12V98
on the road
It’s nice to support your own Country when possible.
edited 12/10/21 08:27am by an administrator/moderator *
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
TxGearhead
Sailun has announced a recall for the Vietnamese tires. Owners should be getting letters.
Details on the Keystone forum.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
momentum rv
Central Cal.
Copied from another thread...
Sailun Tire Americas, Inc. (Sailun) is recalling certain Sailun, RoadX, Blacklion, Blackhawk, and Ironhead brand tires, sizes ST235/80R16 and ST235/85R16 with DOT codes 2020 through 4120. Due to a manufacturing issue, the tires may experience a belt separation. Belt separation could lead to loss of vehicle control, increasing the risk of a crash. Sailun will replace the tires, free of charge. Owner notification letters are expected to be mailed in December 2021. Owners may contact Sailun customer service at 1-844-281-9696.
2015 Grand Design Momentum 385TH
2015 Ford F-350 DRW 4x4 Lariat
Edd505
Elephant Butte, NM
momentum rv wrote: Copied from another thread...
Now you made me go look ....... St 235/85/16 about a year old.
Yep got 3 in that range, no answer at the number listed.
edited 12/10/21 02:35pm by Edd505 *
2015 F350 FX4 SRW 6.7 Crew, longbed - 2017 Durango Gold 353RKT
2006 F350 SRW 6.0 crew longbed sold
2000 F250 SRW 7.3 extended longbed airbags sold
2001 Western Star 4900EX sold
Jayco Eagle 30.5BHLT sold, Layton 24.5LT sold
Splashers3
Oakville, MD
Geez, my Cedar Creek Silverback got 9 years out of one set of Michelin XPS Ribs......enough said!
2017 GMC 3500 Sierra Denali, C/C, D/A, DRW, w/40gal Aux tank, 18K B&W Patriot.
2019 Cedar Creek Hathaway, 34RL2 - w/Bells & Whistles and disc brakes
Traded 2009 Cedar Creek Silverback, GII, 32 WRL
ChuckSteed
Mtn Home, Idaho
YES - NINE YEARS of use wasn't the brightest thing with a set of RV tires.. 5 maybe depending on how they are cared for and weight load and speeds towed at..
But to run a set of RV tires nine years you were lucky you didn't have issue your really didn't want
edited 12/11/21 08:55am by an administrator/moderator *
MNRon
Tennessee
It's unfortunate manufacturers don't publish reliability and longevity data on their tires (for obvious reasons). As ChuckSteed said, running any RV tires 9 years isn't the brightest move anyone can make. Yet, I'm confident that there are some, OF ANY MAKE, that will make 9yrs or more. The issue is that percentages of surviving tires, again on ANY make, will go down with time.
Five years seems to be the consensus break-point where it's time to replace RV tires. Because we don't have data, I'll hypothesize that at 5yrs the survivability of good RV tires is somewhere between 98% and 99.8% depending on brand, and how you run them. At those numbers most of us will never have issues over our RVing lifetime. If you buy cheap china-pop's, overload them, and run them at 80mph that number is probably more like 5-10% but there probably are a few that might survive.
With good tires, and care, I fully expect that most can get well over 5yrs BUT the odds of catastrophic failures go up with time and most wisely don't try to squeeze the extra couple/few years out of their tires. If tire manufacturers would give us better statistical information we could all make better decisions, and maybe get a few more years out of tires but that isn't in the tire manufacturers best financial interest.
If you want to run your RV tires to 9yrs, good luck, but please don't drive next to, or in front of me, on the road...
Ron & Pat
2022 F350 Lariat CCSB SRW Diesel
2019 VanLeigh Vilano 320 GK
