bobndot
Quote: Mine is in the bathroom, and when I sit there with the door closed and the fan on, I can feel a breeze blowing in under the door.
I noticed that too . If the fan is on ‘high’ it might be more difficult to open the door ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif)
Look how much dust gets trapped on the FF screen. Its a strong attic fan.
My previous Lance was sealed so tight , with all the windows, vents and door closed , i could here the pitch difference in the FF motor as I opened the door. I could here the rise in rpm’s of the fan. Try it, see how well sealed your rv is. The class C i have now is not as tight as my previous TC.
The fan works well exhausting cooking odors too.
Kober
Arizona
Skibane wrote: The MaxxAir fans are also worth considering - Very quiet on the 3 lowest speeds, and draw just a small fraction of an amp of battery current.
Personally, I would not own an RV that wasn't equipped with at least one of either brand - They are SUPERB.
Looks like Maxxair is the ticket if only based on their efficiency. Thinking of going that route in a month or two.
2014 Coachmen Freelander 29qb, towing a trailer with my toys:
2020 Honda Talon SXS, or
2006 Royal Star Tour Deluxe
2008 Road Star 1100
PATRIOT GUARD RIDER, AMERICAN LEGION RIDER
Retired 25 years US ARMY, retired 24 years business owner
BobsYourUncle
Calgary Alberta Canada
My Fantastic Fan has a MaxxAir cover on it! ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif)
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
IAMICHABOD
Sunny So Cal
Mine Too !! easy cleaning of the fan and cover with the pin/hinge mounting.
Former El Monte RV Rental
Buying A Rental Class C
EMD360
Arvada, CO
I did the rain sensor one too. It’s a bit loud. I have not experienced it closing without rain but we live in a dry climate. The remote has to be in direct site and we keep the bathroom door closed. But it’s not as loud as the existing fan and of course the wires were right there. I found out some fans are sandwich style and clamp to the roof and some get screwed to the roof top and only trim is installed inside. The original was a sandwich and the replacement screwed to the roof. Not a big deal just a surprise.
2018 Minnie Winnie 25b New to us 3/2021
Former Rental Owners Club #137
2003 Itasca Spirit 22e 2009-2021
bobndot
My rain sensor fan worked fine for 3 years then decided to become independent.
Maybe possessed is s better term ![biggrin [emoticon]](http://www.rv.net/sharedcontent/cfb/images/biggrin.gif)
Some people say there is a small push button type switch on some models that can malfunction and has to be kept clean using a contact electrical spray.
Maybe its something that actually needs to be replaced every few years.
pnichols
The Other California
A reversible RV ceiling vent fan has a little known use that can be outstanding: When traveling on dusty roads or even for traveling in any situation, if needed run the air conditioner or heater on the recirculate air setting, close up every window, and close up every ceiling vent except one with a reversible fan in it. Set this fan to the "blow in" mode, and set it on the slowest or next to the slowest speed setting. The fan then "tries" to bring air into the motorhome but "can't" because everything is closed up. What is then happening is this fan is establishing and maintaining a slight air pressure inside the motorhome.
This slight air pressure keeps all dust out of the interior that otherwise might seep in through small cracks, window seals, door seals, etc.. We do this a lot to help keep the interior of the RV cleaner when traveling - especially in dirty air or when on dusty roads.
Phil, 2005 E450 Itasca Spirit 24V
