RV.Net Open Roads Forum: Fifth-Wheels: hydraulics in cold weather
 > hydraulics in cold weather
SUMRX4
VA
Posted: 12/02/21 07:59am Link  |  Quote  |  Print  |  Notify Moderator
Does cooler weather typically effect hydraulics operation. Winterized my unit last week and when I tried to close the main slides (hydraulic operated) they would move about 6" and stop and the touch screen would say "Fault occurred" I could release the control and touch it again and it would move about 6" and do the same thing. I'm thinking it was just because the fluid was cold and a little thicker. Does this seem typical and if so, is there an additive to help with this issue?
enblethen
Moses Lake, WA
Posted: 12/02/21 08:40am Link  |  Quote  |  Print  |  Notify Moderator
Cold will make hydraulics work slow. Some hydraulic systems use various types of fluid which effects system operation.
What system do you have and what fluid is in it?
Some hydraulic systems, not nessesarily rvs, have screens on the intake to the pump that can become restricted.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
ford truck guy
Pennsylvania
Posted: 12/02/21 08:55am Link  |  Quote  |  Print  |  Notify Moderator
I will say that my limited exposure to cold weather camping has been exactly that.
My jacks would NOT completely go up the first time.. The first time it happened I was concerned, but after asking on forums found it was normal. I have NOT experienced a slide issue as of yet due to cold/thicker Hydro fluid
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Cummins12V98
on the road
Posted: 12/02/21 10:11am Link  |  Quote  |  Print  |  Notify Moderator
My Lippert system calls for Dextron ATF. I long ago removed it and refilled with AMZ/OIL Signature Series ATF with zero issues that many have experienced like popping.
37,800# GCVWR "Towing Beast"
"HeavyWeight" B&W RVK3600
Tom/Barb
Oak Harbor, Wa
Posted: 12/02/21 10:59am Link  |  Quote  |  Print  |  Notify Moderator
Transmission fluid won't be effected by cold weather.
SUMRX4
VA
Posted: 12/03/21 06:25am Link  |  Quote  |  Print  |  Notify Moderator
My unit is a new KZ Durango Gold with an LCI system. Have no idea what type of fluid is in it. Haven’t looked into that yet. Was just here searching for clues.
ford truck guy
Pennsylvania
Posted: 12/03/21 06:31am Link  |  Quote  |  Print  |  Notify Moderator
my LCI system uses Hydraulic Fluid... There was a bulletin out to add a quart of motorcycle fork oil, or CAT hydraulic fluid additive to help in removing Popping sounds that some were hearing.
Cummins12V98
on the road
Posted: 12/03/21 09:04am Link  |  Quote  |  Print  |  Notify Moderator
Thanks, makes sense.
Cummins12V98
on the road
Posted: 12/03/21 09:06am Link  |  Quote  |  Print  |  Notify Moderator
You should know where your tank is located and what the correct fluid is along with the correct fluid level and how to check it.
memtb
Wyoming
Posted: 12/04/21 10:48pm Link  |  Quote  |  Print  |  Notify Moderator
We have hydraulic slides (not sure of manufacturer) and Big Foot Auto leveling. The coldest that we’ve used them was around a -10 F. The did seem to be a bit slower, but didn’t seem to have an issue!
If I were more motivated, I’d go out and see what brand of system we have for our slides. However, as old as our unit is, it’s probably not manufactured any longer! memtb
Todd & Marianne
Miniature Schnauzer's - Sundai, Nellie & Maggie Mae
2007 Dodge Ram 3500, 6.7 Cummins, 6 speed manual, 3.73 ratio, 4x4
2004 Teton Grand Freedom, 39'
2007 Bigfoot 30MH26Sl
