RV.Net Open Roads Forum: towing a popup with 2008 Odyssey - assorted questions
Search only in Tow Vehicles
 > towing a popup with 2008 Odyssey - assorted questions
hertfordnc
Hertford, NC
Posted: 12/06/21 07:44am Link  |  Quote  |  Print  |  Notify Moderator
Planning a big trip with my daughters family this summer. We tow a hybrid with an excursion.
She is looking at renting a pop-up to pull with her 2008 Honda Odyssey.
Probably picking up the trailer around Denver and using it throughout Colorado for two weeks.
The towing guide offers no details on the Odyssey- it just says "3500 lb" for all models and trim levels.
I know my way around towing and tow vehicles but this is new territory.
Is it likely to have wiring for a brake controller?
Does it tolerate operating at its limits?
Thanks
Dave & Ellen Silva
Hertford, North Carolina
2002 Excursion
2007 Shamrock Hybrid
1972 Revcon
agesilaus
North Florida
Posted: 12/06/21 08:10am Link  |  Quote  |  Print  |  Notify Moderator
I don't know anything about towing with an Odyssey but are you seriously thinking about using a popup, in Colorado, in December??
I doubt that vehicle comes with brake controller wiring why not call the local dealership service manager. I don't know if you towed popups before but those tiny tires blow out frequently, do not run them too fast. Also it can be tough to find one of those small tires too.
Arctic Fox 25Y Travel Trailer
Straightline dual cam hitch
Superbumper
hertfordnc
Hertford, NC
Posted: 12/06/21 08:13am Link  |  Quote  |  Print  |  Notify Moderator
Sorry. No. This is a summer trip -
frankwp
Calgary, AB, Canada
Posted: 12/06/21 08:28am Link  |  Quote  |  Print  |  Notify Moderator
I towed a large pop up with a Windstar (definitely a less capable vehicle than an Oddessy) and it pulled like a champ. It had a 3500 lb tow rating & the trailer weight very close to that. Power & stability were not an issue. But I would not do it without a weight distributing hitch.
The trailer had electric brakes, something I would not want to be without in all but the smallest utility trailers.
* This post was edited 12/06/21 08:34am by frankwp *
2010 Cruiser CF30QB
2003 GM 2500HD, crew cab, SB, 8.1, Allison
Posted: 12/06/21 08:54am Link  |  Quote  |  Print  |  Notify Moderator
Wireless brake controller is your easy solution for brakes. Can't comment on the suitability of the vehicle, but being the better part of 15 years old, the miles/condition of it are as important as the as-designed vehicle capabilities.
2017 Heartland Torque T29
Y-Guy
Tri-Cities, WA
Posted: 12/06/21 09:15am Link  |  Quote  |  Print  |  Notify Moderator
This might be of help; Honda Odyssey Towing Capacities From 2000-2020 Good resource - 2008-2010 Models
You can find the Owners Manual here.
2007 Winnebago Sightseer 35J
2011 Jeep Wrangler
wowens79
Georgia
Posted: 12/06/21 09:16am Link  |  Quote  |  Print  |  Notify Moderator
We towed a popup with a Pilot, which is the same engine and trans as an odyssey, but I think it does have a stiffer suspension.
It did do pretty good with it, but it did lighten the front end some. Our Pilot was all wheel drive, and when starting going uphill in the rain, you could feel the front tires start to spin, and then the rear drive would kick in, so not sure how much spinning the odyssey would do.
It does not have wiring for a brake controller, but you can wire one in. I did that on our Pilot, it is not to bad, but you have to run wires the length of the car underneath it, so that is a bit of a pain.
Etrailer.com had a kit for it with all the wiring you need, and even had a video on how to install it.
2002 Chevy Silverado 1500HD 6.0l 241k miles and climbing
2016 Heritage Glen 29BH
2003 Flagstaff 228D Pop Up
Sjm9911
New Jersey
Posted: 12/06/21 09:38am Link  |  Quote  |  Print  |  Notify Moderator
You would need a break controller and most have upgraded cooling systems added. Addtionally, bump stops or air bags to correct the sag. And ot depends on the weight of the pop up. Go lighter and not with the 3500 lb ones. Lots tow with them, but with the added mods listed.
2012 kz spree 220 ks
2020 Silverado 2500
Formerly a pup owner.
agesilaus
North Florida
Posted: 12/06/21 09:59am Link  |  Quote  |  Print  |  Notify Moderator
If you do not want to install it yourself, UHaulit stores will usually install one for a price of course.
mkirsch
Rochester, NY
Posted: 12/06/21 02:18pm Link  |  Quote  |  Print  |  Notify Moderator
Please understand the vast majority of participants here, myself included, tow almost exclusively with heavy duty pickup trucks. Their opinions of smaller vehicle tow capabilities are tempered by what they currently use to tow. They will tell you WHAT THEY WOULD NOT DO, not necessarily what can/should not be done.
Does this Odyssey have the tow package on it now? Does it have a receiver hitch? If it doesn't have a receiver hitch it probably has nothing else for towing. Then you have to factor in the cost of adding all that equipment for just one trip.
If the documentation states the vehicle can tow 3500lbs, it can tow 3500lbs. In the passenger classes of vehicles they usually allow for adequate payload capacity to tow the rated amount, AND have the vehicle reasonably loaded with people and stuff. That is also probably with whatever towing equipment option package the manufacturer provides, but you can emulate that with aftermarket equipment.
