RV.Net Open Roads Forum: Camper Battery doesnt charge while going down the road
 > Camper Battery doesnt charge while going down the road
desertratt1
tucson
Posted: 12/06/21 01:08pm Link  |  Quote  |  Print  |  Notify Moderator
Just curious why my house battery would not charge while driving. I have 2001 Dodge Cummins. Anyone know anything about this and is there a way to have it charging. I just assumed it would charge thru the 7 pin. Also we had check light on our frig i ordered a new dinosaur board put it in didnt change a thing. Would only give check light while driving down the road we constantly have to recent frig would be fine than do it again.
Appreciate any input.
Thanks
BobsYourUncle
Calgary Alberta Canada
Posted: 12/06/21 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
Can't offer about your Dodge, but on my GM I had to put a fuse in to a spot where there was a blank filler pin in order to get +12V at my 7 pin.
Perhaps yours has the same thing. Mines a 2007
Dmax/Allison
2007 Pacific Coachworks Tango 306RLSS - 32'
RV Rebuild Website
Site is live, finally launched Aug 22, 2021 @ 6:53 PM
desertratt1
tucson
Posted: 12/06/21 01:17pm Link  |  Quote  |  Print  |  Notify Moderator
ok i had no clue about that i will take a look.
thank you
pianotuna
Regina, SK, Canada
Posted: 12/06/21 01:34pm Link  |  Quote  |  Print  |  Notify Moderator
It may be best to add a dc to DC charger.
Regards, Don
Posted: 12/06/21 02:13pm Link  |  Quote  |  Print  |  Notify Moderator
1. Have you Confirmed it's not charging at all? (IE Have you checked that you have 12V at the trailer plug?) Dodges don't need an extra fuse.
2. Confirm that current is getting to the battery?
-There is a high likelihood that it IS charging, but your vehicle 12V hot pin is not capable of carrying high amps.
- When your battery gets low, the fridge shuts off, whether on LP or DC.
How quickly depends on which mode you're running. LP only draws a few amps, DC mode = maybe 4hours out of 1 fully charged typ 12V battery, tops.
2017 Heartland Torque T29
srschang
Western NY
Posted: 12/06/21 02:57pm Link  |  Quote  |  Print  |  Notify Moderator
You're not going to get much charging through the factory 7 pin plug. The wire from the alternator to the 7 pin plug is too small.
2020 Ram 3500 SRW Crewcab Longbed Cummins, 2019 Northstar 12 STC
cewillis
Tucson, az, usa
Posted: 12/06/21 03:27pm Link  |  Quote  |  Print  |  Notify Moderator
Right -- need a dedicated high capacity wire from an engine charge point to the camper battery(s), protected with fuses, and solenoid (or equiv) activated.
My simple circuit .
Cal
theoldwizard1
SE MI
Posted: 12/06/21 03:30pm Link  |  Quote  |  Print  |  Notify Moderator
pianotuna wrote:
It may be best to add a DC to DC charger.
I second that !
CA Traveler
The Western States
Buy a test light or voltmeter and check the charge line at the plug. Once it is charging you may need to use larger wire for faster charging.
2014 Grand Cherokee Overland
Bob
theoldwizard1
SE MI
Posted: 12/06/21 03:37pm Link  |  Quote  |  Print  |  Notify Moderator
My simple circuit .
Much simpler and probably more effective is a DC-DC charger.
Modern vehicles vehicles drop the voltage from the alternator to <13.5V shortly after starting. This has is not adequate to charge a house battery. The DC-DC charger boosts that up to the proper charging voltage.
