theoldwizard1
SE MI
CA Traveler wrote: Buy a test light or voltmeter and check the charge line at the plug. Once it is charging you may need to use larger wire for faster charging.
You need to test the voltage AT THE HOUSE BATTERY after the engine has been running for 5-10 minutes. You will be surprised how low t s.
bgum
South Louisiana
As said above the rate of energy flow is very little from the alternator to the RV Battery.
covered wagon
srschang wrote: You're not going to get much charging through the factory 7 pin plug. The wire from the alternator to the 7 pin plug is too small.
My 02 Dodge Cummins does great no mods except it has the trailer plug in the rear and that's what it's hooked to. I know it's too far but, it does great.
When checking you need to take apart the male part of the 7 pin adapter that's mounted on the camper. The guys building these things get piece rate and so that wire doesn't often get stripped... they just try driving the set screw in tight enough to break thru the wire insulation and that's what I have found twice now. Both times fixing these have had good results.
ticki2
NH
theoldwizard1 wrote: CA Traveler wrote: Buy a test light or voltmeter and check the charge line at the plug. Once it is charging you may need to use larger wire for faster charging.
Low voltage is one thing , no voltage is a different problem
'68 Avion C-11
'02 GMC DRW D/A flatbed
ScottG
Bothell Wa.
covered wagon wrote: srschang wrote: You're not going to get much charging through the factory 7 pin plug. The wire from the alternator to the 7 pin plug is too small.
My 03 does great as well.
I don't know about newer RAM's but older ones had a 10 awg wire feeding the 7 pin charging circuit and it passes plenty of power.
bighatnohorse
Gig Harbor - Cave Creek
The fridge could be switching to DC power - the vehicle charge is not enough to keep up with the power drain from the fridge is running on DC power.
That's the first thing that you should check.
Second, after the truck is warmed up and running for a few minutes, check the camper battery (with a VOM) to see if it actually is getting charged from the truck.
After that, you can do all that other stuff that was recommended.
2021 Arctic Fox 1150
'15 F350 6.7 diesel dually long bed
Eagle Cap Owners
“The best lack all conviction, while the worst
Are full of passionate intensity." -Yeats
mkirsch
Rochester, NY
ScottG wrote: covered wagon wrote: srschang wrote: You're not going to get much charging through the factory 7 pin plug. The wire from the alternator to the 7 pin plug is too small.
What's "great?"
If you don't run the battery down much, it does not need much charging.
Geewizard
WA
cewillis wrote:
Right -- need a dedicated high capacity wire from an engine charge point to the camper battery(s), protected with fuses, and solenoid (or equiv) activated.
My simple circuit .
I agree. My setup is the same and has worked for years.
2021 Winnebago Micro Minnie 1708FB
2014 Toyota Tundra Double Cab
300W solar, MPPT controller, LED lights
Xantrex Freedom X Inverter 3000W
2 Fullriver 105AH AGM batteries
Air Lift WirelessAIR and air bags
Hankook Dynapro ATM 10-ply tires
ScottG
Bothell Wa.
mkirsch wrote: ScottG wrote: covered wagon wrote: srschang wrote: You're not going to get much charging through the factory 7 pin plug. The wire from the alternator to the 7 pin plug is too small.
What's "great?"
Mine have had no problem supplying 20~25+ amps continuously when called upon over the last 30+ years. The 10 awg wire trucks of this era used is the key.
There have been a lot of blanket statements made in this thread that simply don't apply to the OP's 2002 Dodge.
edited 12/07/21 09:58am by ScottG *
cewillis
Tucson, az, usa
Much simpler and probably more effective is a DC-DC charger.
Modern vehicles vehicles drop the voltage from the alternator to <13.5V shortly after starting. This has is not adequate to charge a house battery. The DC-DC charger boosts that up to the proper charging voltage.
Adequate current transfer is still required in any case -- thus heavy gauge wire.
My alternator - and I suspect all functioning alternators - charges at a voltage determined by the load voltage. While the load voltage is below ~14.3 to 14.4v, the alternator charges at ~14.4 volts. When the load voltage comes up, the alternator drops to the maintenance voltage of ~13.5v. Otherwise, the load (batteries - truck + camper) would never reach full charge.
Cal
