ford truck guy
Pennsylvania
No bathroom access is a deal breaker for my wife..... and no access to at least 1/2 the fridge as well..
Me-Her-the kids
2020 Ford F350 SD 6.7
2020 Redwood 3991RD Garnet
Sandia Man
Rio Rancho, NM
We have had access on all our rigs but I would not hesitate to deploy a slide as needed, do the same whenever we are overnighting at truck stops, Walmarts, rest areas, and casinos. Never gave it much thought as a deal breaker, using bathroom while underway or on the way is sporadic at best, not a determining factor for us when purchasing a rig. Like anything in life, if it matters to you that is the only thing that counts, enjoy your new RV.
BB_TX
McKinney, Texas
As long as slides were selectable and I could bump the one slide out a foot or so for bathroom access I would have no problem with it.
spoon059
Just north of D.C.
Much ado about nothing. Most gas stations or truck stops have plenty enough room that you can extend the slide the 1 foot that is necessary to get to the bathroom. Having 3 young kids, my wife prefers to use our bathroom when traveling, rather than playing public bathroom roulette. We've never once had a problem.
2015 Ram CTD
2015 Jayco 29QBS
StirCrazy
Kamloops, BC, Canada
in my opinion the larger the unit the more important it becomes. small units are easy to manuver in and around smaller places to use public facilities, having said that I think it would be a deal breaker not having access to a bathroom and bed at least as the older I get the less I want to go into public facilities.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumberqueen WS100
LadyRVer
No access to a bathroom would be a deal breaker for me. My last fifth-wheel had access to sofa, dining table, bathroom and bedroom area. I had to bring the slide-in during a Tropical Storm and was glad I could access all the areas I needed for 3 days.
Michelle.S
Western NY till fall, then Sebring, FL
It would be a deal breaker for us also. With our Front Bath it just requires us to roll over the bed to get there, mush easier than trying to put the slide out.
2018 Chevy 3500HD High Country Crew Cab DRW, D/A, 2016 Redwood 39MB, Dual AC, Fireplace, Sleep #Bed, Auto Sat Dish, Stack Washer/Dryer, Auto Level Sys, Disk Brakes, Onan Gen, 17.5" "H" tires, MORryde Pin & IS, Comfort Ride, Dual Awnings, Full Body Paint
jdc1
Rescue, Ca
Mike134 wrote: mhardin wrote: That would be a deal breaker for me.
X2!!
3X.... My wife would behead me
TXiceman
Full Time RVer
We make do with the 5er without potty and sleeping access OK. If I absolutely have to have access, I can take the bathroom door off the hinges (really easy) and can squeeze in, then access to the bed through the 2nd sliding bathroom door. The fridge has access if I remove the parrot cage from its travel position. Been using it this way for over 8 years. Where there is a will there is a way to make do.
Ken
Amateur Radio Operator.
TxGearhead
We can squeeze by to get to the bathroom, but I usually just open 2 truck doors and water the road shoulder, or a parking lot, or...
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
