RV.Net Open Roads Forum: Beginning RVing: Plugged in or out
 > Plugged in or out
Bfrnk
Posted: 12/09/21 04:36pm Link  |  Quote  |  Print  |  Notify Moderator
Do you keep your rv plug into landline when at home and not on the road?
Posted: 12/09/21 05:00pm Link  |  Quote  |  Print  |  Notify Moderator
I've never had a telephone in a RV....
Presume you mean electrical plug in, aka shore power as it's sometimes called. Depends. But yes more often than not, it's plugged in.
Caution, if you have a cheap converter, it could overcharge the batteries if left plugged in indefinitely.
2017 Heartland Torque T29
Skibane
San Antonio, TX
Posted: 12/09/21 05:03pm Link  |  Quote  |  Print  |  Notify Moderator
Plugged in.
The battery chargers in modern power converters are perfectly capable of maintaining the house batteries in a fully-charged state.
After the batteries become fully charged, the amount of AC power consumed by the converter is negligible - not nearly enough to notice on your electric bill.
pianotuna
Regina, SK, Canada
Posted: 12/09/21 05:11pm Link  |  Quote  |  Print  |  Notify Moderator
No.
Converters are not always optimized for battery charging.
I do have a modest solar installation to keep the batteries (generator, chassis and house) in tip top condition.
Regards, Don
Posted: 12/09/21 05:12pm Link  |  Quote  |  Print  |  Notify Moderator
I did. but then I also used it every day (My Ham Shack)
I did, however. Notice a major jump in my power bill.
BB_TX
McKinney, Texas
Posted: 12/09/21 05:48pm Link  |  Quote  |  Print  |  Notify Moderator
Always plugged in whether in storage or RV park for 14 years and no problem.
Sandia Man
Rio Rancho, NM
Posted: 12/09/21 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
We do as well, we use our rig so frequently that we are fully charged and fridge is always at operating temps for quick getaways. We have smart converters and inverter chargers that incorporate multiphase charging routines to keep our 12 volt reserves happy and healthy, average 8 years with our golfcart batteries before replacement.
Lantley
Ellicott City, Maryland
Posted: 12/09/21 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
plugged in 24/7 365.
The only time my RV is unplugged is when it is traveling down the road.
19'Duramax w/hips,12'Open Range,Titan Disc Brake
BD3,RV safepower,22" Blackstone
Ox Bedsaver,RV760 w/BC20,Glow Steps, Enduraplas25,Pedego
Correct Trax,Splendide
naturist
Lynchburg, VA
Posted: 12/09/21 06:09pm Link  |  Quote  |  Print  |  Notify Moderator
I do keep it plugged in, although I disconnect the battery (connect it for a day once a month to keep it charged). I do this because the humidity here is high all year around, and I keep a dehumidifier running in it to keep mold down. I also, from time to time, need to run the refrigerator for "special events." And every so often we have guests.
bgum
South Louisiana
Posted: 12/09/21 06:16pm Link  |  Quote  |  Print  |  Notify Moderator
Plugged in with dehumidifier on but with converter breaker off.
Solar charger connected to battery with negative wire disconnected.
 > Plugged in or out
