RV.Net Open Roads Forum: Beginning RVing: Plugged in or out
 > Plugged in or out
Anza-Borrego Desert SP area
Posted: 12/10/21 04:42pm Link  |  Quote  |  Print  |  Notify Moderator
No, I don’t. Concerned about surges and low voltage. Prior to buying Lithium battery I used a 30 watt solar panel to keep my Trojans charged when the TT was out of action. Now the discharge is so low, I am unconcerned.
Winnebago 2101DS TT & 2020 Chevy Silverado 1500 LTZ Z71, WindyNation 300 watt solar-Lossigy 200 AMP Lithium battery. Prefer boondocking, USFS, COE, BLM, NPS, TVA, state camps. Bicyclist 14 yr. Army -11B40 then 11A - (MOS 1542 & 1560) IOBC & IOAC grad
time2roll
Posted: 12/10/21 05:53pm Link  |  Quote  |  Print  |  Notify Moderator
Bfrnk wrote:
Do you keep your rv plug into landline when at home and not on the road?
No plug at the storage lot. Plenty of solar power.
675w Solar pictures back up
Bobbo
Wherever I park
Posted: 12/10/21 08:01pm Link  |  Quote  |  Print  |  Notify Moderator
Skibane wrote:
Bobbo wrote:
Plugged in. BUT, I replaced the OEM converter/charger with one that will take care of the batteries rather than boil them dry.
Simple Test: Measure your house battery voltage with the converter/charger turned on, after it has been running for a few days.
If you measure something in the 13.2 - 13.8 volt DC range, your converter is doing a decent job of maintaining the batteries. If the voltage is much higher than that, you're probably going to need to add water frequently.
My Progressive Dynamics converter/charger drops to 13.2v.
Even at 13.8v I think you need to monitor the water level at least monthly.
Bobbo and Lin
Bfrnk
Posted: 12/11/21 01:55pm Link  |  Quote  |  Print  |  Notify Moderator
I do mean shore power not landline. New to rving and I’m not used to rv language enough.
Mike134
Elgin, IL
Posted: 12/11/21 02:01pm Link  |  Quote  |  Print  |  Notify Moderator
no reason to have it plugged in. plus it's 80' from the house
2019 F150 4X4 1903 payload
2018 Adventurer 21RBS 7700 GVWR.
StirCrazy
Kamloops, BC, Canada
Posted: 12/12/21 09:47am Link  |  Quote  |  Print  |  Notify Moderator
min is pluged in when ever its not in use. check water every 3 months, if you have the factory converter check it every month.
Steve
2014 F350 6.7 Platinum
2016 Cougar 330RBK
Veebyes
Posted: 12/12/21 02:42pm Link  |  Quote  |  Print  |  Notify Moderator
Nope. November to April completely disconnected. No trickle charge. Nuthin. One of the pros of an AGM battery bank. No maintenance & very low self discharge.
2007 Alpenlite 34RLR
akkeosflomdis
New York
Posted: 12/14/21 03:33am Link  |  Quote  |  Print  |  Notify Moderator
Presume you mean electrical plug in, aka shore power as it's sometimes called. Depends. But yes more often than not, it's plugged in.
olfarmer
Iowa
Posted: 12/18/21 07:42pm Link  |  Quote  |  Print  |  Notify Moderator
I don't leave it plugged in but do use battery maintainers on it, 1 for coach and 1 for engine battery.
Ed & Ruby & the 2 cats
2001 Winnebago Brave 30W
7.4 gas Work Horse Chassis
99 Jeep Grand Cherokee
Campinghoss@51
Windsor NC
Posted: 12/19/21 10:15am Link  |  Quote  |  Print  |  Notify Moderator
Always plugged in. There is a progressive ems monitoring incoming power, the residential frig is set on 40 F and the batteries are monitored. I prefer to keep the frig on as residential models are made to run 24/7. At times during Thanksgiving we have the inside frig full, the frig in the garage full and have to use the one in the fiver. Plus I keep a small ceramic elec heater set at 32 for a safety net.
Camping Hoss
2017 Open Range 3X 388RKS
2017 F-350 6.7 with hips 8'bed
Lucky & Lucie
 > Plugged in or out
